OBJECT HIT THE CORNER OF MY LCD TV..THERE WAS COLORED LINES RUNNING UP THE SIDE OF THE SCREEN. nOW THE SCREEN IS JUST BLANK
  • paulcosta60 Aug 26, 2008
    THANKS FOR THE REPLY...I FOUND OUT THE PART #BNO7-00245A SAMSUNG WANTS TO CHARGE 1200 DOLLARS PLUS SHIPPING AND THEN I NEED TO PAY FOR THE LABOR...THEY SUGGESTED IT WOULD BE CHEAPER TO BUY A NEW TV....WHAT DO YOU THINK?
    thanks for your help
  • 4,234 Answers
The LCD panel has been broken. There is no way to repair the panel, it must be replaced. If you can post the make and model of the unit, I'll try to get you the part numbers and cost.
Dan
Posted on Aug 12, 2008
  • ABRsvcs Aug 26, 2008
    Unfortunately, because of the cost of the replacement panels, this is often the case. Especially when you add in the labor charges for the replacement which will easily exceed $300.
    Sorry about the bad news.
    Dan
Water damage lcd lg tv
The problem is the buffer board located on the bottom of the screen is burned out. The TV need a new LCD display panel.
Jan 15, 2018 | LG 32LG30 32 in. LCD HDTV
I have multi colored vertical lines across the entire screen. The menu screen is perfectly legible when selected on the remote and will go on and off like it is suppose to.
If this tv vertical colors lines problems happen by itself,tv problems not causes by u or an object by hitting forces to the tv LCD screen panel itself.The tv board that call the T-CON board it is dead,this board sit in the bottom in the middle of the LCD screen panel.Must be replaced the T-CON board to solve tv vertical colored vertical lines.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.If causing by u or an object by hitting forces it to the LCD screen panel itself.The tv not worth a whole tv anymore,because by replacing the tv LCD screen panel will cost the same as a new tv.
Jul 28, 2011 | JVC LT37XM48 LCD TV
Blue line down right side
The blue line came on to the tv LCD screen panel by itself,not caues by u or an object by hitting the tv LCD screen panel itself wright,if yes this problems can't be repair because the LCD screen panel itself dead.Blue line happen by itself,the tv board that call the T-CON board it is dying and the causes.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacemrnt.
Jun 22, 2011 | Polaroid TLX-01511C LCD TV
Westinghouse tx-52F480s. flicker, turned into colored lines. now all black. all inputs. what is the problem. which board?
Most likely the T-CON board it is dead.The tv have colors vertical lines alway causes by a dead T-CON board,if only this problems,happen by the tv itself only.Not causes by u or an object by hitting it with forces,than the tv LCD screen panel it is damages and tv it is worthless as a whole tv set.Because the tvs LCD screen panels are very important to the tvs and it is 90% of the costes of all tvs.The T-CON board sit in the middle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Jun 13, 2011 | Westinghouse TX-52F480S 52 in. LCD TV
My Samsung LN52A550 has colored vertical lines in the middle and right side of the screen is black. Is the problem related to T-CON?
Yes,this problems alway the problems and the causes by the T-CON decodering board.If this problems acurring by it self.If this problems are causes by and an object or a person by hitting the LCD screen panel itself,than LCD screen is dead,not repairable.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
Mar 02, 2011 | Samsung LN52A550 LCD TV
When I turn on my Vizio P42hd I get lines of different colors down the left side of the unit from top to bottom. Is this something that can be fixed? My email is mdrye@holtville.k12.ca.us
This problems is not causes by a person or some objects by hitting ur LCD tv picture screen panel?If,yes,by a person or an objects by hitting the picture screen panel.This tv is not repairable only can be by replaced the whole entire LCD picture screen panel only,sorry than this tv is not worth repairing.Because by replacing the tv LCD picture screen panel itself,will cost the same as a new tv.If these colors strips show up by itself,yes,tv it is repairable.The board call the T-Con decoders board is dead.This board sit right at the bottom right in the middle of the LCD picture screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
Nov 22, 2010 | Vizio P42HD Television
I have a sharp 52d62u with a lot of vertical lines on the whole screen. They vary in color. Is there any fix for this or do I need to find a new tv?
Anybody or an object hit the LCD screen panel,that cause truama to it,than it not repairable.The LCD screen panel it dead.Nobody or an object hit the LCD screen panel.If vertical colors lines it happen,by itself.Than the T-Con board is dead.The T-Con board,that the board,that sit right in the middle bottom of the LCD screen panel.Replaced the T-Con board should solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con board for the replacement.
Sep 17, 2010 | Televison & Video
Aquos LC-42D62U 42 in. HDTV LCD Television: 46 inch lcd screen hit with an object and cracked,...
Sorry,no! Because the LCD screen is about 90% of the LCD tv.No where else u will find a LCD screen for sale.Except the tvs corporation themself,LCD screen it limited produce,so the will charge u the LCD screen replacement same as a new tv or even more after the labors and LCD screen replacement.Ur tv now it only can be salvage as for electronics boards for parts that it.Not worth as a whole tv any more.
May 16, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
