Question about Microsoft Xbox 360 Console
The cd drive
My xbox 360 dropped on floor and my cd drive wont open and there is red light flashing what do i do
Hey i got a solution for you shove it up ur *** you ******** dropped voided warranty micro center doesnt cover that
Posted on Aug 24, 2008
  • 69 Answers
I would call ms and tell them that it just stopped working.
contact details below:
Assistance by phone:0800 587 1102
or +44 20 7365 9792 from a mobile phone
Hearing Impaired (TTY device):
0800 587 1103
Hours of operation:
Monday-Friday: 09:00-22:00
Saturday: 09:00-20:00
Sunday: 09:00-17:00
Posted on Aug 12, 2008
Xbox 360 3 flashing red lights
Well if they're flashing the hard drive is over heating and you need to get either a new hard drive or a new Xbox.
Feb 11, 2014 | Microsoft Xbox 360 Console
My xbox just stop loading my games and it dont have any red light what should i do
if you have got an open tray error then you will need to get a new dvd drive. Alas you cannot just get another xbox 360 dvd drive and change it, as the dvd drive has a unique key that is only for your xbox, to replace the drive it will need to be flashed with your key from your old drive.
Have you tried a cd lense cleaner on it as it might just be dirt inside that is stopping it reading discs.
Feb 27, 2011 | Microsoft Xbox 360 Console
Xbox-360 elite lower right hand red flashing led light code error E73
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 17, 2011 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
No red rings or flashing lights..does not play disc..says open tray..close tray.
You will need to clean the lense on the cd drive.
Either purchase a cd/dvd lens cleaner from walmart or similar store..
Or dismantle the 360, open up the drive, and clean the lens your self with a q-tip and some rubbing alcohol.
Aug 17, 2010 | Microsoft Xbox 360 Console
2 red flashing lights
The Xbox console is overheated.
  1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot.
  2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating.
  3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
To try to prevent this problem, follow these precautions:
  • Don't block any ventilation openings on your Xbox 360 console.
  • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings.
  • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
Taken from Microsoft support.
Best of Luck.
-Mind
Jun 30, 2009 | Microsoft Xbox 360 Console
Xbox 360
It's overheating. Consider buying an external cooler at a local Target or Best Buy.
Jun 08, 2009 | Microsoft Xbox 360 Console
I have 2 red rings on my xbox 360 but i dont understand what they mean...
The 2 flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 2 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 2 red lights. Even before you get the 2 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 2 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that's all.
There is one more option available in the form of DIY Video Guide, that will explain you step by step approach to fix red ring of death within one hour without any technical knowledge.
Jan 13, 2009 | Microsoft Xbox 360 Console
Xbox 360 plays CDs n DVDs but wont play my games, plz help
try calling microsoft again...and if no luck...then you might have to find a replacement cd drive...you can probably get one off of ebay.
Jun 28, 2008 | Microsoft Xbox 360 Console
Flashing 3 red lights
The 3 flashing lights suggests that it's a hardware problem and you'll have to send your 360 to Microsoft for repair. Go on xbox.com and there is a link for repairs.
May 26, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
80 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
