Question about Sony PlayStation 2 (PS2) Console
New ps2 laser wont spin
Hi i was wondering... whats going on? i replaced the laser of my ps2 with a new one.. i desolder the soldered dot and seemed it worked but then i hear strange sounds so then i open it up again to see if i was placed it wrong. and then it does not even spin :S thanks in advance.
  • Anonymous Dec 01, 2008
    Actually i did desolder a dot, not solder. well i had to otherwise would not work.
    i think is made like that from the factory. anyway. the point is i didnt do anything else. just replaced the l whole thing.but it just didnt worked thats all.
    most likely i did fried it but thanks for the reply. ;)
    ill give it a go second time tho. lets see
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
Well you should not have had to solder anything its just a ribbon cable..more than likely you fried it....i think you should start from scratch..you want to replace the whole thing .
Posted on Nov 27, 2008
My Slim PS2 discs won't spin. I just replaced the laser...
put some wieght on the ps2 disk cover flap eg a game cover that fixed mine otherwise i would trash it man ;)
Jul 26, 2009 | Sony PlayStation 2 Slimline Console
It wont read anything
I'm going to say that if it wont read any disk your laser has died but lets try to clean the laser before you do anything else. check out the video below it will show you how to clean your ps2. you said you have the slim ps2 if not use the ps2 large videos they will show you step by step how to repair your system.
if you find that cleaning the laser does not work you can get a new laser lens assembly on Ebay cheap about $10.00 with free shipping. then you will want to use the lens replacement video its good for the full size and slim.
I hope I have been helpful please don't forget to rate and good luck if I can be of any more help just let me know.
PS2 slim disassemble http://www.youtube.com/watch?v=izY7pth8vKI
PS2 slim lens cleaning http://www.youtube.com/watch?v=wGk3UltJ0s0
PS2 slim & large laser replacement http://www.youtube.com/watch?v=QzvKiE-zNAs
PS2 large http://www.youtube.com/watch?v=-FCES1I-oNo
Jul 25, 2009 | Sony PlayStation 2 Slimline Console
Ok so my laser went out in my xbox 360 and i bought a new one and i put it in and now it just wont turn on.... what happened?
there is an anti-static point that needs to be desoldered for the new laser to work. Check the link below and then select what drive laser you are trying to replace...
https://xbox-experts.com/e/tutorial.php?n=laserreplace
Mar 06, 2009 | Microsoft Xbox 360 Console
Removed Laser ribbon
sorry a ps2 **BIG SYSTEM** wont fit ..now the ribbon in some of the old ps2 are thin insted of the wide type and they may fit but if i understand your ? right a ps2 lazer wont fit
Oct 23, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Slim New Lens, Not Spinning
Hi guys,
Well, there is 2 switch. one at  the back left of the cd tray and one one the reset /power switch. both sitch have to be close in order for the disk to spin.
If you try this dont forget to put a disk on the spindle as you will start the laser. this is for your safety. then, if the disk does not spin, then you can try replacing the laser. or at least verify the ribbon cable that is hook to it. if the ribbon cable is not well inside the plug the laser might move but again the disk won t spin.
it is related to each other, the PS2 seem to verify the laser prior to start the spindle so what ever happend to the laser affect the spindle.
and then, if you buy a new laser lens, don't forget to remove the soldering bridge. it is a small ball that is use to avoid static while shiping the lens.
most of the seller will include a small peace of paper with procedure and also there is web site with picture of this soldering bridge.
I replace some of them, and I have to say that the small plastic lock for the ribbon  cable to the lens has been an issue and the soldering bridge another one.
but I got most of the PS2 back and running by replacing the laser.
I hope this will help you.
Feb 26, 2008 | Sony PlayStation 2 Slimline Console
Disc won't spin after replacing laser
Have you replaced the laser yourself? before installing it you should remove a soldered joint on the laser, it is just like two points soldered together, just desolder that and put it back, it will work. Good luck
Feb 02, 2008 | Sony PlayStation 2 (PS2) Compact System...
Laser Wont fire
I had the very same problem with my ps2. What I had found was that I had indeed gotten a nonfunctioning laser. After I installed another new laser, the system functions without any problem. I hope this information helps you.
Jan 05, 2008 | Sony PlayStation 2 Slimline Console
Disks wont spin on new laser
Did you remove the anti static solder blob (point) on your new laser with a soldering iron and solder wick prior to installing it? The symptons your explaining indicate that point is still intact, If so you will need to carefully remove it first then reinstall the laser and try again.
Sep 13, 2007 | Sony PlayStation 2 Slimline Console
Disk wont spin
First of all the new laser lens will not allow your Slim to read NTSC UC games if you have a PAL european Console.
There is no reason the New laser should have not read the disc unless it Came to you damaged. It sounds like you know how to replace a laser.
Disk is not spining
Don't bother changing the lens. If i understand you correctly you have damaged the motor or some circuitry leading to it. I hope this helps! good luck on finding a new one, they are abundant right now!
Jul 21, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
70 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
