1st Generation Ipod Model a1040 The battery last only a few minutes after charging and the ipod crashes when you try to play a song. Once turned back on the battery shows as severly depleated within just a few minutes of being off of the charge.
  • TripleZer0 Jan 23, 2009
    Stupid thing is weirding me out.
Batteries can only take a finite number of charges and they degrade over time.  A 1st gen IPOD is at least 5-6 years old.  The battery is probably bad.  You can buy a replacement battery from Sonnet Technologies (  It comes with installation instructions and is really easy to replace.
Posted on Mar 08, 2009
My ipod will not turn on
Find out what to do if your iPod won't turn on.
Several things could prevent iPod from turning on. Check each cause in this order to find out what's wrong.
Products Affected
Make sure the Hold switch is off
1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
2. To turn the hold switch off, slide it until you no longer see the orange patch.
3. Press any button to turn on iPod.
iPod hold switch on iPod hold switch on
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
iPod battery empty icon
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Additional Information
If you have tried the solutions above and iPod still won't turn on, check the following:
* Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
* Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
* Try connecting iPod to the built-in port of a different computer to see if that works. Note: If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly.
If you still can't turn iPod on after performing these steps, it may need to be repaired. You can arrange for repair at the iPod Service Website.
iPod may not power on, may be stuck on the battery logo, or may have stopped responding while playing music (in which case the Click Wheel doesn't respond).
Products Affected
iPod classic (120GB), iPod nano, iPod classic, iPod classic 160GB (Late 2009), iPod (5th generation), iPod (5th generation Late 2006)
If you experience any of the above issues, try the following steps:
1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
* If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
6. Try putting the iPod into disk mode.
* While in disk mode, connect the iPod to iTunes and try to restore.
* If the iPod is still not recognized by iTunes, the iPod should be serviced.
See and click the Service tab for more information about your service options.
Hope it helped...
May 21, 2011 | Sony NWZ-E436F MP3 Player
IPOd Shuffle 2nd Generation incompatibilities with iTunes
click on your ipod icon and that should be songs on your shuffle, play to see if they really are on there. sometimes it tricks you...
Jun 08, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Ipod 5th Generation Video froze and is now dead
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Mar 26, 2009 | Apple iPod nano 3rd Generation
Pc crashed and want to move my music from itouch to new pc
You can try Tansee iPod Transfer which can backup songs and videos in iPod to PC, copy iPod songs and videos to new ipod, computer or notebook.
How to Transfer Song from iPod to Computer
Some useful information you can get on the official site:
Nov 28, 2008 | Apple iPod touch
Ipod nano can not play songs from beginning
It droped once (it wasnt a serious drop) a month ago. After that drop it worked well. Problem occured after last sync a week ago.
Jul 24, 2008 | Apple iPod nano 3rd Generation
Ipod doesnt play
did it work before?
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
If you need more assistance let me know. Good luck.
Mar 31, 2008 | Apple iPod nano
Apple ipod nano blue 4gp
hey, select your model from this webpage and do all the steps it suggests.
If after all that the ipod still doesnt work properly contact apple or your dealer for more help.
Mar 16, 2008 | Apple iPod nano
IPod mini battery dies when nearly fully charged, often while skipping songs.
iPod batteries are cheap on $5...and come with installation instructions. Try installing a new battery and see what happens...?
Feb 11, 2008 | Apple iPod mini 2nd generation MP3 Player
Ipod problem - playing songs in order
sounds like you need a new hard drive, which has a little read-write disk in it that is getting finicky... just to get more use out of it lay it on side or other positions and hear if works ok...if so its diffently Hard drive. you know the sandisks are 2 gigs no moving parts why doesnt somebody put 20 together making 40 gigs and replace the failing Ipods!!??? just pure electronics and no moving parts and much smaller...not like a hard drive. I thought of this over 30 years ago looking at the first plug in video game.
Aug 31, 2007 | Apple iPod shuffle MP3 Player
2,815 people viewed this question
