Question about Black & Decker B2000 Bread Maker
I have and enjoy making a loaf of regular bread with my bread machine model K6769c serial # LD13 but wish to use the other settings. I need a manual and the recipe book that goes with the machine. Can someone help me. Thanks
Try this link............has a lot of manuals on it
http://www.useandcaremanuals.com/manuals.asp?ID=1
Posted on Sep 07, 2008
I just want to set my machine for a loaf of white bread, ? Bought it at a thrift store , no manual!
What make is it? Is it 1 pound or 2 pounds loaf?
Here is a basic recipe, for white bread.
1& 1/3 cups lukewarm water.
2 Tbls powdered milk.
1 &1/2 salt.
1 Tbls sugar.
2 Tble butter or marg.
3 & 3/4
1 tsp. yeast.
put ingredients in pan in order of written.
Select the BASIC setting and REGULAR or DARK crust.
push button to star, depending on the breadmaker you have, you may have 15 minutes plus time delay.
the unit will beep when done.
remove bread let cool a few minutes and sometimes you have to remove the paddle inside the bread.
Hope this helps. :)
Sep 09, 2017 | Kitchen Appliances - Others
What size loaf does it make?
I went google and typed in--user manual for abm-100 bread maker machine -- and the first site to open is welbilt abm-100 owners manual pdf down load to give you the manual for the operation of the machine
to get the size of loaf it makes you will need to go google and type in ---recipies for abm - 100- bread making machine---as different breads require different amounts of ingredients which will make different size loaves
from memory most machines make around a 600 gram loaf max
Dec 11, 2015 | Welbilt Bread Maker Machine Owners...
Thought getting this one would be a nice upgrade. Ive tried several white bread recipes, most from other b&d bread machines as the 2200 doesnt have any. Every loaf is a failure! Tried best f
If you could have said how the loves were a failure, maybe I could have helped. Also if there is no white bread setting on your machine maybe you won't be able to make a white loaf.
I would like more details if possible.
Oct 24, 2014 | Kitchen Appliances - Others
I lost the manual for Breadman Trillium 500. What size loaf does it make?
Bread pan Capacities
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
My pay pal account is the same as my email, any thoughtful contribution you make would be appreciated. daryl441@msn.com Best Wishes, Daryl Nash
Jan 04, 2011 | Breadman TR500 Bread Maker
E:02 error on Chefmate Bread Machine Model HB0215
The power surge has damaged the machine controls. File a complaint and request for compensation for the damage with your local energy supplier.
Jul 01, 2017 | Chefmate TR 7000 Bread Maker
Broken arm
I have a Mr. Loaf Bread machine Model HB-210-215 Serial # I F I 4
The kneading blade has broken. Where can I get a replacement?
Jun 25, 2009 | Salton Double-Loaf Breadmaker Bread Maker
Baking gluten free bread in model 5890
good day,
hope this link below will solve your problem.
Set your bread machine program for 1.5 loaf medium crust. I used the gluten-free cycle on the Breadman; if you don't have a gluten-free cycle, I believe a rapid rise cycle will also work.
Check the dough after a few minutes of kneading- it should be closer to a muffin batter than bread dough, soft but not too wet. Adjust dry to wet ratio with a tablespoon of flour or warm liquid, as needed. Humidity influences the dough. As does temperature (your bread will rise higher on a hot day).
If you like a crusty loaf, remove the bread from the pan and place it in the oven at 350 degrees F for an additional 10 minutes- keep an eye on it and don't let it get too brown. It should be a light golden color.
Cool the loaf before slicing for best results.
Enjoy fresh from the oven- the first day (as with most gluten-free baked goods) has the best texture and taste
Read more: http://glutenfreegoddess.blogspot.com/2009/02/delicious-gluten-free-bread.html#ixzz0ZZASptEr
Dec 09, 2008 | Sunbeam 5890 ExpressBake Bread Maker
Chefmate bakery oven model cm 725
Since practically all bread machines work the same simple way, you don't need the manual if you read the excellent instructions at the following website. The following website tells you how to operate a bread machine, even if you don't have the manual. It also includes great recipes (and you can easily find many more recipes online). Using the following website, I was EASILY able to figure out how to use my Chefmate 725k bread machine even though I didn't have a manual.
http://hillbillyhousewife.com/breadmachinemanual.htm
By the way, the Chefmate 725k holds 16 cups of water which means that it should be able to make a 2.5 lb loaf of bread (though I've never tried to make a loaf that big). If I'm making one loaf of bread, baked in the machine, I'll generally make a 1.5lb loaf. But more often than not, I just use the bread machine to knead and raise 2 lbs of dough. Then I remove the dough (with rubber spatula) cut it into two equal parts, and then put the two pieces of dough into separate 5" x 8" x 2.5" bread pans (if I want a traditional shaped rectangular loaf of bread) or on a cookie sheets in round or oval shapes. I don't really care for the shape & style of bread that is baked in a bread machines.
Dec 05, 2008 | Chefmate TR 7000 Bread Maker
HOME line Bread Maker
Sounds like my exact problem. I bought in an antique store (here in Vcr-Canada) an un-used machine. Home-line "Home Bakery" Mod.CBM-5511.
1-lb loaf capacity. With lots of auto-settings.
A lady friend at work took it home yesterday and made me a wonderful loaf based on the instructions and recipe for her new Black & Decker model. It all came out Great.
I wolfed that loaf when I got home tonite. I even copied the simple recipe that she used for making the bread and for some other doughs to make buns ect. I'm gonna try it out on my wife soon. I LOOOOVVVVE breads.
Aug 17, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
