Monitor does not come on, but system loads, thus I need to fix the monitor issue with the dos prompt, if possible, any answers
  • Coss May 11, 2010
    Have you tried hooking up a different monitor?
    That will determine if it is the monitor, or maybe a problem with your video card.
    Novelist:
    Scholar:
  • 141 Answers
Sorry can't fix monitors with Dos prompts these days. Try another monitor that you know works. Make sure both plugs from the monitor are plugged into 1) wall / 2) video card on computer.
If still no monitor try a new video card.
Posted on Aug 12, 2008
Display only in safe mode
It is possible that your computer is not able to start up (normally), e.g. problem with your Windows XP, Windows 7, etc. ... e.g. you see a blinking cursor at the top left corner of your (blank) blue screen.
If this is the case, you can try to repair your disk first ... in save mode, get to a DOS prompt, i.e. >
You may see options/commands (at the DOS > prompt) by typing HELP. One of the programs that attempts to repair the disk is CHKDSK. Type at the > prompt: CHKDSK /? to see the options
Then, run the CHKDSK command to repair the boot disk.
After completing the chkdsk, type EXIT (to go back to Windows). If necessary, shut down and power up again and see if the boot disk has been repaired.
In the worst case, you may have to restore your disk from backup, or boot from a back-up (boot disk / CD) to fix the boot disk problem. But first try to save/store all your (personal) files (while in SAFE mode) before you reformat the disk and re-install the operating system (from an installation / boot CD disk)
Mar 04, 2014 | HP Pavilion F1703 17" LCD Monitor
Cannot load Windows 7 from hard drive. Possible with recovery discs.
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 31, 2012 | Computers & Internet
Slow boot windows 7
Well, the reason may be one or more problems acting together. The problem nowadays is that it is very difficult and time consuming to monitor and take care of your Lenovo PC. Even experienced users find it hard to perform such tasks on regular basis because you might need to prepare a huge amount of time and energy to deal with each issue separately.
If you want to fix the problems more efficiently, try the Lenovo speed up program, available here: http://www.speeduplenovo.com/
May 03, 2012 | Lenovo Computers & Internet
BLUE SCREEN
Which Operating System? You'll need a system disk to run the chkdsk command for a Dos Prompt (black screen with white lettering).
Insert the Operating System Disk in the cd drive, reboot from the operating system disk and select the option to Repair. It will search for your operating system and once found you will select it by entering a 1 for windows. Then it will ask for the Administrator's password which in most cases is blank so just press enter. When you see the Dos Prompt simply enter the command: chkdsk /r
Check disk will run well over an hour and you will notice the percentage of completion going from high to low, but that's normal. Let it run to completion then reboot the machine.
If you still have issues, then you'll need to reinstall windows. Try doing a Repair Install which preserves your music, pictures, documents, data and videos.
Windows XP Repair Install:
Insert the Operating System Disc in the cd drive and boot from it.
When the Options come up select the Option to Install Windows (Don't select Repair). It will start loading windows files and at some point it will ask you to accept the License Agreement by hitting F8. On the next screen after hitting F8 it will begin searching your system for an already installed operating system. It should find yours and give you more options to which you want to select the option to Repair. This will preserve everything you have on the system.
In windows vista to get to the dos prompt you will need to use the operating system disk and boot to it. Then get into the Recovery Console and look down at the bottom for the Dos Command Prompt or Repair option.
Mar 22, 2012 | Intel Computers & Internet
Toshiba 1205-5813 will not load windows up. When power on computer and log on, the next screen i go to is a black screen with my cursor just showing
Can you go in via safemode if so one of your drivers might be of issue.if you get in try this start run type cmd hit enter once,the dos prompt appears at the prompt type chkdsk /r.you will see a error message stating this volume is in use do you want to run scandisk on startup instead answer yes restart it will start repairing itself on reboot.Good luck
Aug 28, 2009 | Toshiba SATELLITE Notebook A205-S5813
Windows Xp wont boot up
try starting windows in safe mode and go to an earlier system restore point if that wont work try installing windows again if windows wont respond to this it will be a hard drive issue it will need replacing
Jan 22, 2009 | HP Pavilion dv9000z Notebook
HOW DO I GET INTO MS-DOS PROMT
  1. Click Start.
  2. Click Run.
  3. Type cmd or command and press enter.
Jan 18, 2009 | Compaq Presario C700T Notebook
MS-Dos prompt in Windows 2000 & Xp
u can just press alt + enter when u r running ms dos prompt in xp or 2000, it will show u full screen and u once again press alt + enter it will back to normal mode when u come out u just type exit from the command prompt
Mar 16, 2008 | Computers & Internet
Acer 5100 will not logon
Try it in SAFE MODE... this will fix errors... then restart the computer.
Jan 30, 2008 | Acer Aspire 5100 Notebook
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
