Question about Philips WACS700 Shelf System
Wacs700 hi there wanting to connect to pc cant find my cd rom but got everything else , is there a way around this without?
I take it you have use Wac DMM and given it the folder where your music is stored...
All you have to do is rip your CD to that folder and then upload it.
Posted on Sep 21, 2008
How to replace hard drive
Hi, everything you need to know about to replace the HDD on Philips WACS700 can be found here: http://www.scribd.com/doc/12808150/14051wacs700-How-to-open-Philips-Streamium-WACS700-courtesy-of-AndrewT
I have done this myself and must admit that it is a bit fiddly. You need to be a bit handy, know your way around with electronics and have access to screw drivers/soldering equipment and electronics pliers.
Good luck.
Dec 09, 2012 | Philips WACS700 Shelf System
How can i download my canon pixma270 to my new pc without my cd-rom
Go to this link >> http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp270#DriversAndSoftware
Enter your system information and you can then download your drivers for the printer and any software that may have come with it.
Jul 28, 2012 | Canon Office Equipment & Supplies
I've bought a new PC running 64 bit Windows 7, and my installation disk won't load. Anything that can be done?
Yes if you have the Phillips WACS700 and want to install the software that came with the system to upload/download music and you have a windows 7 or Vista you need to open the explorer and go to the CD/DVD folder then look for the .exe change the properties of the .exe files to run in compatibility mode "compatible with Windows XP SP2", then run them from the explorer. I have a Win 7 computer and both software that came with the CD did not wanted to run because they required XP, as soon as I change the properties of the files they ran and installed without a glitch, everything worked as it should and I been able to enjoy my music on the WACS700.
Nov 12, 2010 | Philips WACS700 Shelf System
Cannot use pc cd rom on vista coputer
what type of cd rom you want to use???
maybe it is the board where you connect your cd rom...
i've also experienced that i cant connect my cd rom..after a while noticed that my power cable is the problem..the power supply of my computer can't handle to much load maybe because it is old...i try my cd rom to different pc and it work..
try to check your cables...or check if your power supply still good in it's output voltage...
Feb 06, 2010 | Broderbund American Greetings Creatacard...
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
How do i install without the CD-ROM
when you connect a new pc to your modem, reboot the modem (by unpluging power and reconnect power & it will automatically detect the pc,
then reboot the pc and you will be connected ...
with xp no driver needed
Apr 12, 2009 | Arris SURFboard® SB5101 Cable Modem
Canoscan Setup Utility CD-ROM missing
How can i install my canonscan 20 without the cd rom
Sep 07, 2008 | Office Equipment & Supplies
Wacs700 connection to my pc via wireless
use http://www.lucia-mathias.com/wacs/, it will find music center as long as security settings for wireless are correct, if never connected to a pc use the original pilips disc to set up first
Aug 13, 2008 | Philips WACS700 Shelf System
CD rom
hi
open your pc case
open screw of rom then remove power and data connection from rom then pull your rom.
then install dvd burner.
power and data code connect.
install burner soft
ok
u have done
Mar 24, 2008 | Dell Dimension 2350 PC Desktop
Philips WACS700 Shelf System Logo
171 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
