Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
Chirping and not coming on
The chirping is more like a cricket and is 17 chips at 10 seconds. There is no smoke or smell. Sounds like its coming from the bottom right side of the tv (looking from the back) and the only light that comes on is the light in the power switch.
  • Mendonca Aug 19, 2008
    If I purchase the convergence amps (7044 and 7045) will I be able to tell where they go if I don't have a schematic for my 51PW9303?
  • blacksmokeen Jan 19, 2009
    I think I have the same problem, but I'm not sure what parts you are talking about replacing. When I try to power the tv on, it makes the chirping sound and no picture. It's a chirp per second or there about. And it never stops or pauses.
  • Philips Master
  • 3,459 Answers
Goto the site www.TvRepairKits.com and get their "chirping" TV repair kit. It will fix the problem of the dead set with high pitch sound or chirping sound.
Posted on Jan 26, 2009
  • Edward
    Edward Mar 22, 2009
    Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
  • 138 Answers
Replace the defective Convergence
Amps (7044 and 7045) on Small Signal Module.
932212344682
Posted on Aug 19, 2008
  • Lawrence Smith Aug 19, 2008
    When the Convergence Ampa go out the set willmake a chirping sound and the set will not come on.Also the HVG (5904) 312226832865 could be defective also that will be the only 2 reasons for the set not working.
    There are no instrutions on replacing the baord it is easy just make sure the set is unpluuged. Put it together the same way you will take it out.If you came do a computer this should be a piece of cake.
I have no pic or sound except a chirping noise , sounds like a cricket , LOL , timer light stays red , there was a odor , like a burnt smell
Hello. The chirping probably indicates a shorted transistor or diode, and the burnt smell usually indicates a blown capacitor or a burnt resistor, or multiple damaged parts. I would have to see the TV to be of any further assistance. Sorry I couldn't be more helpful. Good luck.
Oct 29, 2015 | Akai PT5492S 54" Rear Projection...
How to fix a hard wired smoke alarm that won't stop chirping
you don't say what kind of smoke alarm you have, or what kind of chirping, so i'm assuming it's a once per minute chirp which usually indicates low battery, but can also indicate that the unit has some other problem...if the unit is more than 10 years old you should replace the entire thing (per NFPA72, the national fire code, all smoke ALARMS must be replaced every 10 years)...if this is newer than 10 years, try replacing the 9 volt battery being careful to follow any instructions that may have come with the unit or may be printed on the back, top or sides...good luck.
Oct 16, 2015 | Home
Alarm went off but no smoke was found and no other smells were detected. I do not believe that there was CO present. All the units were activated. after a period of time they stopped. This occurred 3 times...
http://www.kidde.com/Documents/User-Guide-900-0102-A-ENG.pdf Remember that smoke take presidence over C/O detection so notice whats going off first . LED Indicator Operation
Red LED
The red LED will flash as described below under the following
conditions:
--During smoke or CO alarm, with every beep
--During testing (same as alarm)
--Low battery, single flash with chirp
--End of product life, double flash every 30 seconds with chirp
--Unit error mode, single flash with chirp
--Unit error mode, a Fault Code is flashed every 30 seconds (can
be observed and reported to customer service for
troubleshooting. Above is the user guide.
Sep 09, 2013 | Kidde 9000102 Night Hawk Combination...
Smoke detector keeps chirping after battery is changed, chirps every 30 seconds. chirps come from the ceiling not the device
The chirp means the battery you chose wasn't good enough... it has to be the newest '''alkaline''' you can get hold of. If it isn't alkaline that's why you are having trouble. Upon replacement press the button to do a hard reset.
Aug 11, 2013 | Kidde Home
3 new Kidde i4618 smoke detectors were put in last week. Last night one of them began chirping. I went to the store and bought brand new batteries and replaced them and tested the units which all worked....
smoke detectors work by smelling the air across a radioactive anode which upsets the electronics and sets off the alarm
it can be set off not only by smoke but by heat and gasses in the air
the new and better product is a photo electric detector which alerts earlier and can be installed connected to each room and into the house power or they come with a 10 years lithium battery
It could be a faulty unit so take it back for a warranty exchange unit
Oct 30, 2017 | Kidde 4618 Firex Hardwire Ionization Smoke...
Chirps about every 30 seconds
The chip indicates a bad battery. I didn't look up your model but, if it is supposed to charge battery, which I'd doubt and, if it has a 10 year warranty on the battery, Kidde should replace the abtteryand/or unit, otherwisw I would think you would void your warranty. I'm sure you can find a repalcement battery if you had to and the chirping is really annoying so maybe you can remove the battery to make it stop, but you will have to leave it unhooked until you resolve your problem because it will still chirp if installed with no battery.
May 02, 2011 | Kidde 0910 10Year Sealed Lithium...
Rubber smell chirping sound smoke
I am assuming that the smell, smoke and chirp are from under the hood.
That would be a pulley locked up, most likely the serpentine belt tensioner.
Nov 13, 2009 | 1995 Dodge Stratus
Sound
it sounds like the chips have been eliminated, if so......
1) turn ignition "on" and then "off"
2) within 10 seconds push the valet buttons three times
3) you should get 1 siren chip indicating the chirps are now "on".......if, you get 2 chirps then you just eliminated the chirps.
May 22, 2009 | APS787 Prestige Remote Start and Security...
Wondering if you got my response yesterday.
really sorry. i missed to reply you among a lot of requests
well this happens do to a faulty color wheel sir.
and you will need to see for some kind of loose fittings and will have to replace the full wheel if needed.
Aug 13, 2008 | Philips 51PW9303 51" Rear Projection...
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
237 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
