Question about SanDisk Sansa m250 MP3 Player
Roommate's sansa mp3 player
My roommate has a sansa mp3 player, formatted for pc. None of us have pc's however, we only have Macs. Her mp3 player won't mount when I plug it in, and I'd like to reformat it for Mac, but it won't show up. Any suggestions?
  • 55 Answers
Hey
goo to supprt area & find your drivers click here
dont forget rating this post if this is not helping u tell me so i can help u further .
Posted on Aug 20, 2008
My Sansa Fuze won t recognize certain songs
you need to check the format the songs are in, try putting them in mp3 format
Mar 28, 2010 | SanDisk Sansa Fuze MP3 Player
My sansa clip is frozen how do i reset
1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry\ For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using media player -> start Media Player If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu, Click the pencil icon on the upper right corner of the window. Click OK to start formatting. Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the device. It is usually the last device listed. Right-click on the device and select Format Click OK to format.
Jan 24, 2010 | SanDisk Sansa Clip MP3 Player
My Mp3 player is frozen on a file it says it's chargeing when its not
1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry\ For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using Media Player -> start Media Player If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu) Click the pencil icon on the upper right corner of the window. Click OK to start formatting. Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the device. It is usually the last device listed. Right-click on the device and select Format Click OK to format.
Jan 23, 2010 | SanDisk Sansa m250 MP3 Player
When turned on the screen displayed FAT is
First try to reset the player 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry -- For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using Media Player -> start Media Player **** If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu) Click the pencil icon on the upper right corner of the window. Click OK to start formatting. ***** Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the player. It is usually the last device listed. Right-click on the player and select Format Click OK to format.
Jan 23, 2010 | SanDisk Sansa Clip MP3 Player
Hi, I unplugged my sansa by accident while it was formatting. Now it says there is no free space left in it but .. it has nothing on it at the same time. and it doesn't show up in my computer as a sansa...
try formatting the h drive and see if it works... if that doesnt work,download sansa updater from here http://mp3support.sandisk.com/sansa/Installer/1083/SansaUpdaterInstall.exe run the updater while your player is connected to pc and it should download the appropriate firmware
Aug 31, 2009 | SanDisk Sansa e250 MP3 Player
How do i fix it
My roommate had that problem, it ended up being the usb cord, but if its not you may want to try reinstalling the sansa drivers without it being pluged in. here's a link http://www.sansa.com/support. always try to get your drivers from a manufacture, some other sources may leave u a risk for a trojen
Jun 05, 2009 | SanDisk Sansa m240 MP3 Player
Formatting
try plugging it into your computer. go to my computer, and double click sansa 260 (or what ever yours is) then you should see a drive called internal memory, right click and reformat . You'll still lose your stuff tho.
Nov 08, 2008 | SanDisk Sansa e200 MP3 Player
My sansa e250 mp3 wontt play songs.
try to format your mp3 using the cd included in the package if there is any... if none, google for the software of your pc and format it using the software...
Aug 26, 2008 | SanDisk Sansa e250 MP3 Player
My computer doesn't recognize the Sansa c240
The songs are in the wrong format - convert them to mp3
Read my "Tips and Tricks" on song formats for more detailed info
Mar 31, 2008 | SanDisk Sansa c240 MP3 Player
Sansa can't conver wmv...
Use Crazi Video for Sansa. http://www.riverpast.com/en/prod/crazivideo/sansa/
Apr 11, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
61 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
