Question about LG Cell Phones
LG vu was in water - works but colors are not correct on the screen - will it dry out and correct or does it need replacement
    Genius:
  • 1,011 Answers
Dear,
swithc off your mobile and open its board then put in under heat of high wattage lamp 200Watt is enough but make a little distance of about 5-6". remain it there for half an hour and then try again ...
remember, remove your battery and then do these steps..
otherwise serious problem
if still nothing happened then u have to replace it.
regards,
dont forget to rate it
Posted on Aug 12, 2008
SOURCE:
Touch screen doesn't work
You will need to replace the touch screen to get it to work. This is a common problem with the Lg VU
Check out the following link for a video on how to do that and links to buy a new touchscreen.
Repair LG VU CU920 Touch Screen
Jun 15, 2010 | LG Vu CU920 Cellular Phone
Jg vu end button wont work
This is a device issue due to water damage. You will need to contact your service provider for replacement options!
Mar 17, 2010 | LG Vu CU920 Cellular Phone
LG Vu phone fell in water and touch screen is not working.
Really your only option is to get a different phone. Since there is water damage it voids your warranty so you would have to turn to insurance. If you don't have insurance you may be able to do an upgrade or you would have to buy one outright. If you can't do that than you can get a prepaid phone and put you sim in that and it will work.
Mar 14, 2010 | LG Vu CU920 Cellular Phone
Cracked screen, now lines running up and down screen
Its all one piece on the vu. as long as the plastic lens covering the lcd is still intact. Its a fairly easy replacement Ive done a few!
Mar 01, 2010 | LG Vu CU920 Cellular Phone
My vu touch screen phone has water in the screen!!
The first thing to do is take out the battery to prevent electical damage.
Leave the battery door off and place the phone screen side down in a warm, dry environment (an airing cupboard is ideal if you have one).
You should leave it for several days, as the moisture will take some time to work it's way out. It could take a week or more.
You could try it again from time to time, but you will have to be patient.
It may not recover 100%, but it is possible.
Feb 21, 2010 | LG Vu CU920 Cellular Phone
I dropped my lg vu in a cup of water for only a few seconds and now the screen barely works and the buttons are screwed up!!!! Please help!!!!
put ur phone in a dry plastic bag and close it tightly the water in ur phone will stick to the sides of the plastic bag even then if it dosent work contact your mobile expert
Jan 11, 2010 | LG Vu CU920 Cellular Phone
Lg vu water damage
Let it dry completely without the battery and it may come back to life. If a red mark appears on the cell then it is ruined and will have to be replaced.
Jul 06, 2009 | LG Vu CU920 Cellular Phone
Fog in the screen of the LG VU
um dont worry this will go away soon just get a hair dryer and should fix fast!!
Jun 06, 2009 | LG Vu CU920 Cellular Phone
TOUCH PAD ON MY LG VU QUIT WORKING
You need to replace touch pad. Parts cost around $25. Fairly easy to replace. Once you see it you will know how to replace, Go on ebay and put in lg vu touch screen and you should pull up parts for your phone. Or just google lg vu replacement touch.
May 15, 2009 | LG Vu Cellular Phone
LG VU screen doesn't work after water damage
I was cleaning the pool when my LG Vu took a dive. I fished it out in about 2 minutes...should have jumped in and it would have been in only seconds.....anyway. Dried it off with my shirt and pushed the lock button to unlock and see the screen...it was on but said Emergency Download. I took the battery out and dried it off also took out the SIM card and memory card. Shook the water out; some drips here and there, fortunately it wasn't water-logged. I let it sit for about an hour and got on the internet to find a remedy. I took advice to put back the memory and SIM cards and plug in to charger....the screen directed me to put in the battery....so far so good. The screen said the battery was charging. I waited patiently for that to finish. When complete, unhooked the charger and hit the unlock button again....what do you know the screen came up! I was estatic! But....the touch screen would not work!! Back on the internet for advice. Decided to do the hair dryer trick. I set the dryer on cool setting and let it blow on the screen. I also opened up the chargers portal and let air blow in there. I took the cover off the back to the battery and let it blow on there....being very careful not to let the battery fall out and not let the phone get hot. I did this for about 30 minutes. There was some fogging of the screen so I focused more on drying the screen with the dryer. The fog cleared up and when I touched the touch screen the top of the screen started working first...bottom still not responding...a little more of the dryer and all worked!!! Screen fogged again in about 20 minutes...dryed it again with dryer and it has been dry ever since. I have gone to every application, etc. on my phone and everything works just like it did before it took a dip! Hope this helps some of you! Key is patience, and some drying with TLC! Best of Luck!
Apr 29, 2009 | LG Vu CU920 Cellular Phone
Cell Phones Logo
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
