Question about Kenmore 15343
Kenmore sewing machine 15343
As soon as I start to stitch the top thread binds up down near the bobbin, and then it seizes up(doesn't move anymore) If it doesn't seize up the only stitches that stick on the top are the first and last stitch....and It doesnt seem to be incorporating the thread from the bobbin at all. THANKS!
I had this problem but have resolved it (for the most part) by lowering the needle down into the fabric before beginning to sew.
Posted on Aug 20, 2008
SOURCE:
Necchi 4575 feed dogs won’t work does not push material through
If you raise the presser foot, set the stitch length to a 3 or higher, then slowly press the foot control, can you see the feed dogs rise, move backward, then drop and come forward again? If they are not moving, the feed dogs have seized. If they are moving but do not rise above the needle plate, then you have them disengaged.
If they are seized, resist the temptation to run the machine anymore until you can get it serviced. It could damage the motor causing more repair cost.
If they are disengaged (dropped), then you need to find the control lever or dial that engages them.
Jun 23, 2018 | Necchi Sewing Machines
My kenmore 22 stitch sewing machine I bought in 1990; it doesn’t reverse anymore. How do I fix it
Those older machines do need regular cleaning and oiling. I suspect the oil has dried and caused the switch mechanism to seize. As time goes on, more parts may seize, so it's probably important to get it addressed soon. It could eventually damage the motor if the motor is trying to move seized parts. Well worth the expense if you value your machine.
Mar 19, 2018 | Kenmore Sewing Machines
Pfaff tiptronic 2040 My bobbin thread isnt catching and now is making a noise
Sounds like your bobbin isn't locked into place. Is the latch on the bobbin worn that you can see? Is the shaft worn that the bobbin locks onto? I'll search for a manual but this is where I would start looking. Good luck
May 21, 2017 | PfaFF Sewing Machines
Cant get the feed teeth to come up and grab the cloth -- the cloth wont move --do I have it set on darn ?
it is possible that you have the feed in the neutral position ( halfway between forward and reverse ) from your problem discriotion
Apr 24, 2016 | Singer Sewing Machines
Showing E6
You receive the error message E6 when the motor locked up because thread is tangled or the machine is seizing up.
Remove the tangled thread, it it still happens that means your machine is seizing and requires service.
Apr 30, 2014 | Brother CS-8060 Computerized Sewing...
When i start sewing the thread tangles and seizes up within 3-4 stitches. I've removed and cleaned the bobbin case a few times.
change the needle
make sure the thread has not come off of the thread take up lever
rethread the machine top & bobbin,, make sure to use every
thread guide
make sure to not over fill the bobbin,, make sure the bobbin is not
warped or damaged
Aug 31, 2012 | Janome DC3050 Computerized Sewing Machine
Hi, my lower tension will not adjust no matter what I try. The top stitching is fine but the lower stitches are very loose. My machine is quite old but in good condition. It is a model 2201 EC1 Series. I...
Be sure to ALWAYS RAISE the presser foot when threading the top thread. This allows the thread to seat completely in the tension disk. The higher the number on the tension disk, the tighter the top tension. If the bobbin thread is laying on the surface of the fabric, try increasing the top tension.
Thread tension is basically a tug-of-war between the two threads. They should exert the same amount of pull against each other. Perfect tension is when both threads meet in the middle of the fabric.
Of course, since your machine is older and parts do wear, your machine may need an adjustment or even replacement of some parts, like the bobbin case. The tension spring on a bobbin case will wear over time and the top tension may lose some of its tension.
TIP: Be sure to treat your machine to some well-earned TLC--cleaning and oiling. Oil dries out over time and will begin to stick parts so they no longer move freely. Below is the method I've used to free seized machines. You'll be amazed at how nicely it runs and your machine will run for many more years!!!
Wheel on right side that controls the needle up and down is very tight...
Oh yeah, here's a manual:
https://www.manualslib.com/manual/1143961/Toyota-Rs2000-Sd-Series-Stf17.html?page=45
Nov 25, 2017 | Toyota STF17 Sewing Machine
Won't sew with foot dog down and using the freehand embroidery foot
Won't sew can mean more than one thing - the machine has no power or is seized up; the needle is not going up and down; the needle and bobbin are not forming a stitch.
When the feed dogs are down, you move the fabric by hand.
The presser foot has to be down to stitch.
If you wound a bobbin before you starting the sewing, did you disengage the bobbin winding feature(s)?
Mar 20, 2010 | Bernina Activa 140
Mechanical sewing machine binding
Usually what we see with these machines is that the hook drive gear behind the bobbin case seizes up check here first and lubricate this area .
Jan 13, 2009 | Brother XL-3510 Mechanical Sewing Machine
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Sewing Machines Logo
252 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
