Question about HP LaserJet 1022n Printer
HP LaserJet 1022 Error Message
The Printer keeps indicating that the Front cover door is open or the cartridge is missing
  • FixIt1234 Nov 17, 2008
    Have replaced toner cartridge, manually held down the 'door closed' indicater (like your refrigerator light 'switch'), powered off and on, etc. Still says the front door is not closed or the toner cartridge is missing.
I had exactky the same issue. The problem is not with the front door or the cartridge. I solved this as there was a very small paperjam. If you take out all the paper and shine a torch into the printer you may find a small piece of paper stuck on the sensor that is causing the problem
Posted on Dec 31, 2008
The first time I got this signal, I shook the ink cartridge and fiddled with the cover. No luck. I took the paper tray out and slid it in again. Apparently the roller tried to pick up two sheets of paper instead of one, which bent the papers as though they'd been treated with a curling iron. After reading the items above, I took the paper tray out. That's when I found the bent papers. Problem solved.
Posted on Mar 18, 2009
Check the back of the device. There is a small blue rectangular piece in the back that helps with the guiding of the paper. Unscrew the two phillips-head screws and remove the piece, make sure that it can freely move, then reinsert it.
Posted on Feb 16, 2009
  • jeanpeterson Feb 06, 2011
    I had the same problem - this solution did the trick. Thanks.
I have a issue with hp laserjet 1022 having cartridge missing error please provide some needful helps
Hi
Make sure you installed HP toner cartridge for your printer. and Insert is correctly into the printer. Try to use the old toner cartridge and check if this is the problem.
Just replace new toner cartridge and i might solve your problem. Regards
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 11, 2011 | HP LaserJet 1022 Printer
HP LaserJet 1020 won't print. Error: HP LaserJet 1020 has the front cover door open or the toner cartridge is missing. The door is closed and the toner crtridge is installed properly. I tried to upgrade...
Did this just suddenly happen or was it after you replaced the toner cartridge or opened the door?
I have found that if the toner cartridge is not completly positioned into the printer, it can give this error.
Feb 23, 2011 | HP LaserJet 1020 Printer
I have an HP Color Laserjet 3600n with error 10.10.03
Thank you for contacting FixYa with your printer issue.
www.hp.com Support Document (110993)
10.XX.YY SUPPLY MEMORY ERROR Description The printer cannot read or write to at least one print cartridge memory tag, or at least one memory tag is missing. Action
  1. Open and close the front door.
  2. Remove the print cartridges, and then reinstall them.
  3. Close the front door.
  4. Turn the printer off and then on.
  5. If the error persists, contact HP Support.
Helpful CLJ 3600 Error Message Tables:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478&prodTypeId=18972&prodSeriesId=501044
Hope this helps helps. Please keep us updated and remember to rate this answer.
Jan 22, 2011 | HP LaserJet 3600n Printer
Triagle light blinks on HP Laserjet 1022
If only the triangle light blinks then is because one of the following reasons:
1.The print cartridge door is open.
2.The printer is out of paper.
3.The print cartridge is installed incorrectly. Try opening the door, removing the cartridge and installing it again. It should snap into place.
4.There is a paper jam. Remove the cartridge and check if there is a paper jam.
Feb 06, 2010 | HP LaserJet 1022 Printer
Front cover dore open or cartridge missing
Try reseating the ink cartridge and see if the cover door is firmly closed.
Mar 27, 2009 | HP LaserJet 1020 Printer
Hp LaserJet 1000 series printer error message on front door cover and toner cartridge missing
hi..
ijust solved this issue
WHOA ...
my printer is HP 1020,, and i was printing a huge number of sheets, which USED TO GET STUCK IN AGAGIN AN AGIAN... coz, i was using a low quality damned paper..
now,, it began to gave error ,tht either the front cover door not closed , or its toner cartridge missing.
Well,, simple solution for me was (which is basic i think)
>> Remove the metallic plate on the back of the printer
>>there you 'll find , on the right side, near the socket for poer cable, a "lever" like thing, thats the lever for the "barrier" between the SENSOR... move it and u'll get an idea..
>> if its jammed ,, then free it..
(mine was stuck into dont know wht, and i freed it, and all is fine)
>> if spring adjusment is wrong, correst it(you may get idea by moving it again n again, whether it comes bbacl to its orgignal position or not...
> remore the tonor cartidge and insert it back while looking on the lever movements.... and you ll get whats the matter with it..
PLEASE note it,,, that i think,, the sensors are NEVER damaged !!! mind it.....my knowlegde says , sensors are hardly damaged ..
-----Adios.... Tauseem Omer...Ravian Kemcolian.
Nov 11, 2008 | HP LaserJet 1010 Printer
Error message "cover door is open or printer cartridge is missing"
Try to find the latch in the cover that presses a switch to indicate it is closed it is usually a small stick projection at the sides of the cover. Replace the cartridge it should fit snuggly then try it again.
May 28, 2008 | HP LaserJet 1018 Printer
HP LaserJet 1020--Problem with error message when no apparent error
Try for a reset option. I cannot say which it is with your particular model- Usually it involves switch off- depressing a combination of button then with the buttons still pressed - switch on. Try www.fixyourownprinter.com
Jun 16, 2007 | HP LaserJet 1020 Printer
HP LaserJet 1022n Printer Logo
1,151 people viewed this question
Ben Johnson
