Question about Nikon D70s Digital Camera
Shutter release locks up periodically when taking a large series of photos, then after a while will start working again.
    Problem Solver:
  • 8 Answers
Same problem as mine. Made a sick sounding noise and flashed err then started working fine again after switching off. Happend sporatically while taking a series of shots.
Then today died completely. I take 600+ shots per day 5 days a week, so not unexpected on a 4+ year old camera...
The mirror is what is actually causing the fault and may eventually jam completly as mine has.
Unfornunately, I cannot even select "mirror lock up" in the menu as it is greyed out while the error is active.
The mirror release will need to be serviced to prevent the problem in the future. Once the problem starts it will just get more regular and worse until it ends up like mine.
On the plus side I just brought a D300 to replace it :)
Posted on Aug 13, 2008
I have turned camera on and set up to take a photo and the shutter release button will not press in to take the photo. I used the camera yesterday and it worked fine!
Turn the camera on and look into the view finder while you try to press the shutter button. Check the information in the view finder to see whether you are getting an error message. If you see an error message in the view finder, remove the lens cap and proceed to take a photograph but, instead of pressing the shutter button this time, press the button near the top of the camera on the back which says "AF/AE. If the camera takes the photo it means you have somehow initiated the auto focus/auto exposure lock which the camera will not override when attempting to take a photo using the shutter button. When you use the AF/AE button, you override this system. To remedy this issue, when you get the error message try pressing the shutter button again. Also, remove the lens to see if the shutter inside has frozen in the "locked" position. If you find this to be the case you will need to contact Nikon Customer Support. The link for Nikon Support is below. The numbers are half-way down the page.
http://support.nikonusa.com/app/answers/detail/a_id/238
Oct 31, 2010 | Nikon D40x Digital Camera
I have an old 35 mm Canon A1. I can't get it to click a photo or advance. It has a new battery. This happened to it once before and it turned out something had accidentally been switched on that froze...
Once the film has been advanced, it can't be advanced again until you take a picture. There's a dial ring under the shutter release that locks out shutter release. Turn the dial to unlock the shutter.
Feb 14, 2010 | Cameras
My the shutter release button isn't working
I'll give you a couple: 1. Is your mode in shutter priority or focus priority? Check your menus and go into the AF area to see which one it is. If it's in focus priority you will have to be focused on a subject before the shutter releases. The other setting is 'release priority' which will enable you to snap the shutter regardless if you're focused or not. If you tried to re-compose the picture you were trying to take, you may have locked in focus and then when you re-composed it was not in the same area thus not releasing the shutter.
2. 2 button re-set.
Jim Silva
Jun 19, 2009 | Nikon D40x Digital Camera
I have a Sony DSC-H5 and the shutter button does not allow me to push it half way -- only all-the-way -- the macro won't focus.
It is a common problem on this model. You need to replace the control assembly to fix the problem. Here is a link to show you how to replace the assembly and where to get the part.
How to replace the shutter button on SONY CyberShot DSC-H5 digital camera
Jun 08, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
Shutter won't release
If the lighting is low and shutter speed is set for a long period of time its the function of the camera taking the picture. If it is a malfunction of the shutter take it in for cleaning you might have foriegn material stuck in your shutter mechanism
Jan 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
Error Code
No, it's not an error. What this display indicates, is the availability of the total number of photos you want to take. If the display says, "r06", then you are in JPEG Mode. If it says "r03", then you are either 1) in RAW Mode, or 2) have your Noise Reduction on (see FAQ #2). As you take a few photos in succession, you will notice the indicator drops by how many photos you took.
Mar 01, 2008 | Nikon D100 Digital Camera
Lower half of photos dadrk when printed
Set camera to B , open back door and release the shutter and keep it open while you inspect focal plain area. Is the shutter fully opened ? If you release again is the shutter opening completely and closing completely ? While the shutter is fully opened on B look through the shutter/ mirror box area is anything obstracting your view ? Seems like one of the shutter curtains is not opening properly and shutter will need servicing. Please note that it may not be economical to repair : $ 150-200 if the shutter block does not have to be replaced completely.
Apr 22, 2007 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Shutter won't close on Nikon D70s
Format the card. I have same problem with mine ---requires a new shutter assembly.$40.00 item and they want $300.00 to fix it at Henry`s cameras. Ouch .Better to buy a new camera.
Nov 19, 2006 | Nikon D70s Digital Camera
No picture is taken when shutter release button is pressed
Are those NiMH batteries? Have you tried resetting the camera? If no standard way, just take out batteries for a few minutes, the more the merrier, let the tension build, and replace them. Try tapping on the lens area, it might loose something up. Best I can do, know it aint much ;] Good luck!
Jun 01, 2006 | Nikon COOLPIX Cameras
Nikon D70s Digital Camera Logo
65 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
