Question about Acer Computers & Internet
On my acer backup I get error report (fail) code 0xF0000014
    Genius:
  • 1,011 Answers
How was the procedure for backup.
was the error came while doing the backup..
what was the destination..
regards,
Posted on Aug 12, 2008
    Guru:
  • 1,894 Answers
Restore the system to factory settings
drive needs to be FAT32, not NTFS
  • dewan nafees ahmed Aug 12, 2008
    some one already has had your problem. exact same problem.
    failed Error code = 0xf0000014
    1. do restore the system to factory settings
    2. options were drive needs to be FAT32
    3. use eRecovery system as a alternate option.
    many of the forums and web pages indicating this problem wont be in English. but those are the three important options.
    thank you
  • Acer Master
  • 19,396 Answers
Memory?
  • Ginko
    Ginko Aug 12, 2008
    This can be either a problem with one of the RAM module, a Windows problem, or a problem with a different device.
    Quickest thing to do is testing RAM, either you use a replacement RAM module, or if your computer has two modules you remove one of them at the time to test it.
2 Suggested Answers
Nerdy_geek
  • 94 Answers
SOURCE: When trying to do a
the error code refers to unreadable stack on the program possible a corrupted file system.
to recover your file i would advice this recovery program its kinda useful for recovering files.
www.grc.com/spinrite.htm
Posted on Sep 18, 2008
Spindle test Failed (Error code: WCD44-RVH)
Spindle usually refers to the spinning axis of the carbon disks or the platters. The disks are likely not spinning and a drive replacement is required.
Jun 25, 2014 | Dell Inspiron 530 Desktop Computer
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003
http://support.microsoft.com/kb/973455 - workaroundissue12
Apr 20, 2013 | Computers & Internet
Back up error.....i need more help please
check out this link for the solution.
http://www.pagestart.com/win7br0x8100003301.html
Dec 28, 2011 | Acer Aspire AX3400U2022
When I try to create a system restore point it comes up with error 0xf0000014 and does not allow me to create the restore point
I suspect a running program is stopping your restore point being made. Go into task manager and stop all unecessary processes and try again. Should work now. Also its possible that your antivirus is causing the trouble so kill that too.
Good luck
Jun 04, 2011 | Acer Aspire™ T180 PC Desktop
Attempting a user backup I receive an error 0xF0000014. What is this and how do I correct it?
Your computer is a Acer im assuming and the software is acer Erecovery ?
Check your system partition is NTFS and not FAT32, if its FAT32 you need to convert it
Sep 11, 2009 | Computers & Internet
After a failed download of 2a windows update and an acer one ( installed partially) Its been a couple weeks so I can't recall if the computer shut off or if I had to manually had to do it. Then it wouldn't...
Dear Kid_collecto,
As you are able to access the menu from F10 , atleast try using checkdisk for error's and then try again the restore ...
ERROR 0xd000000d Explanation:
This error is directly being contributed from the inability to read files at a certain point from the master , hidden backup partition.
In Simple words, the master data in backup partition is corrupted. This is where the operating system installation files are kept.
Beyond this point it involves contacting the manufacturer or a local system tech to remedy the issue. (if its under warranty, i suggest taking it to the service centre)
(If warranty is over:)
Another way is to call your local service centre and look for the OS Installation CD. ACER may be able to provide you with that.
Once you have it, you should be able to reinstall your operating system.
Hope this information helps. If it does, please do rate this support.
Thanks & Best Regards,
Techno-Geek.
Apr 07, 2009 | Acer Computers & Internet
BIOHD-5
hello there
depending on the error code it is hard to determine what the problem is
but here is a link that should cover almost all of the codes
  1. C H a P T E R 1 - Troubleshooting Tools POST diagnostic and error message reports are displayed on a console. ... 0) Tests Failed:0 Elapsed Time: 0:0:0:25 If you specify a path argument to test ...www.scribd.com/doc/16604965/C-H-a-P-T-E-R-1-Troubleshooting-Tools - 94k - Cached
Mar 25, 2009 | Compaq Computers & Internet
I have a acer aspire 5100 pc notebook when i trun it on is they ant no harddrive found
Is the hard drive physically present?  If so, perhaps it has failed on you and it's time to replace the HD and restore a backup image or using whatever backup solution you had.  Of course it's possible the connectors came loose, but it's unlikely.  I notice you put a laptop problem in the Acer PC Desktop category; you fail to correctly present your question, but I'm sure you have improvements in the works.
Nov 16, 2008 | Acer Computers & Internet
Computers & Internet Logo
120 people viewed this question
Brian Sullivan
Brian Sullivan
