Question about HP LaserJet 5200tn Printer
943 service print head error
What to do for 934 service print head error
    New Friend:
  • 63 Answers
Sounds like a mirror motor error(this is the laser mirror that spins very fast 20k rpms, you hear the sound when its about to print ,sounds like a jet spinning up). In this case you will need a pro to look at it or replace the machine....
Posted on May 03, 2009
My printer show error init unable 4f
Probably print head or the print head PCB is faulty.
Dec 09, 2014 | Brother DCP-J140w Wireless Compact Inkjet...
I kept getting service error 5200 when I tried printing something. How do I fix this problem?
Hi there
Service error code 5200 is the print head error. Rub the print head into a plain paper with rubbing alcohol until ink flows and then after that remove all the USB cable connection and power cord and plug it again. Then run the print head cleaning maintenance like print nozzle or print alignment.
It should be fine right now. Please let me know if you need more help
Mar 07, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Dell 934 printhead error
This error would require you to replace the print head. Please rate the solution
Regards.
Nov 02, 2010 | Dell W5300N Laser Printer
PRINT HEAD ERROR
there are several different printhead errors 931 933 scanner motor died scanners bad. 932 934 935 are loose lock errors these can be caused by either the scanner or the engine board
Nov 09, 2009 | Lexmark Optra T614 Laser Printer
934 service Printhead error
head may be damaged, try reinstalling software first before you try to send the head repaired locally. may have to buy a new head if its dot matrix.
Jun 24, 2009 | Lexmark T632 Laser Printer
I have a Lexmark T632 that is used very often. Constantly printing over 1000 pages daily and I always get the error message Print head Error 934 - Lost Lock condition but once I shut down the printer and...
These error codes indicate a problem with the mirror motor circuit in
the printhead assembly or the mirror motor cable to the system board
cable or system board assembly. Check the continuity of the mirror
motor cable connected to J5 on the system board. If incorrect,
replace the cable. The voltage at J5-7 measures approximately
+24 V dc. If incorrect, replace the system board. If correct, replace
the FRUs in the following order:
• System board
• Printhead assembly
Dec 10, 2008 | Lexmark T632 Laser Printer
U052 error
UO52 error is either a print head temp sensor error or faulty EEPROM data from the print head. You need to re-set the print head. If that fails then a new print head is required.
http://www.tradebit.com/filedetail.php/4588590-canon-pixma-mp960-printer-service-manual
Complete Pixma MP960 service manual from Canon
Sep 24, 2008 | Canon PIXMA MP960 All-In-One InkJet...
Print head assembly on my Lexmark Optra S 1855 needs to be replaced. My question is what causes the print head to malfunction in the first place?
I guess you're getting an error message which is normally one of the below (causes underneath)
Error Code 931
No first HYSNC Signal
Error Code 932
Lost HYSNC =
These errors usually indicate a
failure in the HYSNC signal to the
printhead. Check the continuity of
the cables connected to J3 and J8
on the engine board. If incorrect,
replace the defective cable. The
voltage at J8-4 measures
approximately +5 V dc. If incorrect,
replace the engine board. The
voltage at J3-7 measures
approximately +24 V dc. If incorrect,
replace the engine board. If correct,
replace the printhead assembly.
Error Code 934
Mirror Motor Lost Lock
Error Code 935
Mirror Motor unable to
reach operating speed =
in the printhead assembly or the
mirror motor cable to the engine
board cable or engine board
the mirror motor cable connected to
J3 on the engine board. If incorrect,
J3-7 measures approximately
engine board. If correct, replace the
engine board
printhead assembly
Jun 19, 2008 | Lexmark Office Equipment & Supplies
My canon mp830
Error code 5200 means the print head temperature is too high. The only was to resolve this error is either replace the print head or replace the logic board. The print head is available, part number QY6-0061 but you will struggle to find a logic board. The only other thing you can try is resetting the EEPROM on the logic board, this sometimes clears the error. A service manual will show you how to do this: http://www.tradebit.com/filedetail.php/4546483-canon-pixma-mp830-printer-service-manual
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
HP LaserJet 5200tn Printer Logo
692 people viewed this question
Seeker5211
Seeker5211
