Ooops.... I accidentally unpluged a couple pins in my mother board. And I don't know where exactly they go. They are the pins in the bottom right hand corner to the lower right of where the battery is. It will not power up.All I know is it says VH611 on the board. Thanks for the help!
  • 2 more comments
  • scrumners Aug 12, 2008
    One said "power" the other "LED" I got the power on but it says "CPU unworkable or changed please recheck CPU soft menu"
    It still wont boot up passed that.
    Thank you for helping!
  • scrumners Aug 13, 2008
    I replaced the bettery and I retstored it to "Fail Safe" mode in CMOS andI still keep getting the same message. Is there any way to boot it up?
    I tried removing the battery and restarting but got the same message. I can't get into the the bios until after I get the message. It still doesn't work :(
  • scrumners Aug 14, 2008
    It comes up "CMOS Checksum error - defaults loaded" but doesn't go any farther than that. How can I check to see what the cpu speed should be? Thanks againg for the help.
How did you get load to fail safe mode in cmos? Was there an option for Last good known configuration? Try a new cmos battery leaving the old one out for like 30 min. Push the power button and quickly hold down del key until you see a blue screen which is the bios. Usually at the bottom of the screen you will see options. Find "load default settings" select it / F10 save and exit.
Also make sure the cpu is set with the correct speed. Over clocking may cause this. Or when you pulled the plug it can change a lot of settings. Hopefully you didn't short anything on your board when this happened. If all fails have board/cpu checked out. But if you haven't messed with the cpu settings in the bios before you should be able to at least get into bios. I'd try a new cmos battery first, possibly memory second then board/cpu. Good Luck Again.....
Posted on Aug 14, 2008
    Novelist:
    Scholar:
  • 141 Answers
Go to the manufactures site of *********** board and get the wiring diagram. It's not as scary as it seems. You can try looking for the wire you may have unplugged. It will have the same amount of pin plugs unless its more than one wire. If so usually if you look on the black plug on the wire it should have an abbreviation like hdd, restart, power light ect.....
Do you think it was your power plugs?
Posted on Aug 12, 2008
  • Theresa  Smith
    Theresa Smith Aug 13, 2008
    Try removing your cmos battery for a few minutes which should bring your system back to default. If you get a normal bootup make sure your time is set correctly by right clicking on time (bottom right on taskbar). If you don't get a boot up, try to get into the bios. After you power up immediately press "Del, F2" or which ever your bios uses. Look for the key F6, F5 ect. that sets system back to default. Hit F10 to save and exit. If that doesn't work let me know. Good luck
  • Theresa  Smith
    Theresa Smith Aug 14, 2008
    PS. sorry I answered you thru my email so didn't show my name. Please try to let me know if it boots.
I have a gigabyte ga 81865gme775 mother board, can you give me the front pannel connection details
hello jknr09
my name is ausi
i can not find your motherboard on gigabyte web site. however the boards nowadays are standard as far as front panel header goes.
on gigabyte mother board you will see the hedae as two rows of pins like this.
the bottom row first 4 pins are the speaker pins. the next single pin is void the next two are reset switch. the last two are hard disk lead.
the top row first two pins are message lead (usually not used). the next two pins are power switch exactly opposite the reset switch.
the power lead connection on gigabyte boards are a three pin header next to the front panel header.
hopefully this is helpful.
please vote for me
Jan 20, 2011 | Intel Motherboard
My pc processor not hit when on the mother board my mother board is aopen mother board plaese give me salution
If you mean that your processor pins does not fit in your motherboard, then they are not compatible. The processor pins must be exactly fit the motherboard.
Besides, the processor type must be supported by the motherboard (If the motherboard is supporting P4, Core Dou, Quad, Celeron, Athlon, etc). You have to install the right processor for a particular motherboard. You have to know what particular
processor is supported by your motherboard.. In your
case, I believe it supports Pentium 4, but I cannot
give you the exact speed in Ghz, as well as the clock speed. You can ask the dealer about it.
Nov 22, 2009 | AOpen (MX4SGI4DN2PRE) Motherboard
I want to disable chasis intrusion switch. Beacuse mother board perfectily well out side cabinet ,but does not boot after fitting inside cabinet
ok do it only if u r a professional..'
refer to the extreme right-hand-bottom [as ur back panel to the left n cpu to the top] of u r mother/main board..in here there is a 3-pin jumper named 'CHASSIS'..place a jumper or set it to pin-2-3 [the middle n right pins respectively]..
hope it'll work..for reference :
http://www.filefront.com/4169747/P4GE-MX-Users-manual-for-English-Version-E1862/
always better to seek professional advice of ur system admin/vendor....
Nov 16, 2009 | ASUS P4GE-MX Motherboard
MY COMPUTER WONT TURN ON !!!
for connecting these sw
just see on mother board there you see nearabout 16 pins on right hand bottem of mother board
there you have an integation of connectorfrom right hand corner i.e 1-3 for reset sw, 2-4 for power sw and last switches for front usb and audio
if you have p-3 then you dont attech audio and usb cables on *********** board
Apr 07, 2009 | Computers & Internet
Motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
Jun 02, 2008 | Intel Desktop Board D815EEA2 Motherboard
Motherboard
I have one sitting in front of me , unfortunately I cannot get it to you but will be happy to tell you the positions. It's not very difficult to fix and I will stick by until you get it correct. I hope I don't complicate this in an attempt to keep it clear and don't be insulted by my answer. I am guessing you don't have a great deal of experience working inside the box and it can become confusing. This is much easier than the length of this answer suggest. You will do this in about 30 seconds, move anything that is in you way and make a note of where it came from. If your hand is small you are lucky but don't force anything and if you are pushing on anything trying to get down there see what it is before pushing more. Better to move it.
There is a front panel connector that is on the bottom right of the board if you orientate the board by placing the computer access panel in front of you with the front of the computer facing to your right. Then right below the floppy disk controlled socket (the smallest flat cable in the box) if no floppy the empty socket below the battery.
There is a double row of pins, looks like 2 rows of 10 pins each. Mine are multicolored, pink and green etc. and the should be marked + and minus, at least plus. The number 1 pin is on the left. The 1 pin is actually the bottom left and the 2 pin is above it. Back down to the bottom row and pin 3 is right next to 1 and the 4 pin right above it. Pin 3 is the second pin on bottom left. Follow the way it goes? The bottom is 1, 3, 5, 7, 9, 11, 13, 15, 17, 19 and right above 2, 4, 6, 8, 10, 12, 14, 16, 18, 20.
Pin 2 is + so put your Power SW on pin 2 and 4 with the colored wire on pin 2. Colored wire in the pair should be positive, and it can be blue, red, green, mine is red and white.
The Power LED goes right next to the Power SW on pins 6 and 8, the colored wire on pin 6, mine is blue and white. And finally the HDD LED goes on pin 7 and 9. All counting from the left to right. My pins are not marked as I think its not critical how the LED is connected and if it does not light then reverse those 2 pins. My colored wire is on pin 7 and its blue. May as well finish, the Reset button is wired to pins 17 and 19 with 17 being positive and the speaker if you have one hooked up (your tiny internal speaker not for listening to music) is a 4 pin connector with the middle 2 sockets empty and fits over the last 4 pin s on the bottom right. 13, 15, 17, and 19. Pin 13 is +. There may be other wires but I don't know where they go depends on what they are but this is what you need. Good luck. And make sure all is unplugged and touch the box to ground yourself or wear a strap. Look but don't touch is a good rule for now.
Feb 22, 2008 | Computers & Internet
USB
On your Mboard there are pins grouped together as such
Now below these pins there should be a message USB 4 or USB Front or something to that effect.
using your USB Cables starting from left to right on the top row of pins plug in this order RED - WHITE - GREEN - BLACK, you should be left over with the last spare pin on the far right. Plug the second USB Cable in the exact same order in the secon row
If your pins are such . . . . .
Then Just Plug the USB Cable The same way but going from right to left starting with the RED plug on the far Right hand side
let me know how you go
Regards
Jan 29, 2008 | Mercury P4VM800M7 Motherboard
How to keep the speaker pins to motherboard
for that purpose you need the manual of the Motherboard if you dont have it download for the manufacturer site of the board in the support or download section.
Jan 06, 2008 | Intel Pentium 4 , 2.8 GHz (SL77ND)
Mother Board connection
Go to the site below. Its a manual for the 800/i65GV group. Go to page 67 and zoom in. You'll get a nice look where everything goes. Two rows of pins. Upper row and bottom row. Real close to each other. Do not place connectors up to down. Connect only left to right.
The reset connector has two pins. One will be white or black. These are - grounds. So connect it to the bottom row onto the most right two pins. Moving to your left. Skip one pin. Take the Power Switch a two pin connector. Remember Black & White is ground & ground goes to your right for both rows of Mb pins.
http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4p800/e1324_p4p800.pdf
Go to IDE_LED next. Its the last two pins towards your most left of the bottom row of pins. Move to the upper row & the power LED. Same as the bottom row keping the grounds to your right. Lastly is the speaker. Its connector holds four pins but you only use two. One in each end.
Good luck & please vote....
Dec 22, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computers & Internet Logo
63 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
