PC problem What should I clean it with?There is a lot of dust in the PC. I have opened out the main fan and got rid of all the dust from this point.
  • Quality76 Aug 17, 2008
    I have done all of this, removed and reconected all power cables coming from / to the motherboard. Now when I power up the fans come on but no beeps and nothing on my monitor.
    Any thoughts?
    Champion:
  • 209 Answers
If you know the ram, that looks like a ruler with about 4 to 5 inches length you need to clean its contact point with pencil eraser. you can blow the dust with a blower. to verify the problem temporarily, remove the video card then use the on board vga. if this does not boot that means the problem now is your memory card push the lock on both end to release then clean as i've stated from the abve.
Posted on Aug 12, 2008
  • JOSE BAUTISTA
    JOSE BAUTISTA Aug 17, 2008
    since you have already done everything as you've said one reason now is that your power supply it shows that it lacks power although the fan is rotating, there are other voltage supplied by this, you can check the other voltages.
Won't power-up or boot after turn off. has to cool 8hrs. to work again.now it turns off a lot more
Take a can of air and blow off the fans. One inside the little metal box called a power supply inside the main case.
Also the cpu has a fan and heat sink on it that gets dust built inside and needs cleaning.
Warning, always unplug the power cord. Make sure you are touching something metal in the case while touching the inside of the PC. It can protect it from static shock.
Also never shake an air can. And don't spray while it's upside down. The liquid can seriously burn you.
May 16, 2016 | Acer America Acer Aspire 5600U-UR308 -...
How do I clean the dust out of my PC?
Turn the pc off and unplug all the wires and peripherals that are attached onto it.
The desktop chassis should have a side panel that comes off, that is screwed onto the body. once you get the panel off, you can use a can of compressed air to get rid of the dust and debris from the fan, air vents and the heatsink.
Here's a pretty neat tutorial with do's and the dont's, on how to go about cleaning your desktop. give it a read before trying it out.
http://www.wikihow.com/Clean-the-Inside-of-a-Computer
Jul 16, 2014 | Acer Aspire Computers & Internet
How do i clean the fan on a sony vaio vgc-lt2s
Cleaning the fan should be a fairly simple task and is best done by using a small artist type paint brush to loosen any dust that can be seen and a straw to blow away the majority of the dust , a hand held vacuum cleaner can also be of assistance to extract the dust or a regular vacuum cleaner but care should be taken in regards to how fast the fan spins as spinning at a very high speed can damage them , also there is usually a exit point in which the hot air is able to escape after been sucked in through the fan opening passing over the computer components which it cools and then leaves via a exit point as warm air , this exit point can also trap dust and needs to be cleaned in a similar way .
Jul 07, 2014 | Sony VAIO Computers & Internet
Noisy cooling fan
Hello! You may have a cheap and loud fan. If it was not noisy earlier, you may have to clean it. It is not difficult at all. First, buy the cheapest clean compressed air spray on the market (approx $5.00-8.00). You just unscrew the computer chassis, and look for all fans. IMPORTANT: before you open the chassis, UNPLUG the PC. Now, if you don't want to "un-cable" the whole PC, just open the windows in your room. Spray the air onto the fan and below the fan where the heatsink is. A LOT of dust will fly blow off, you'll see.
Where are fans in your PC?
1.) On the CPU heatsink.
2.) one or two in the Power Supply Unit (where all the cables are coming out, kind of a metal box - just spray into it too.
3. Graphic card
4. Chassis fan(s)
Clean them all with the airflow from the compressed clean air can.
In addition I'd recommend you clean the other parts and boards, so you have a nice clean PC.
You may watch the attached video too, if you want to go deeper into it, but in my case it always helps. Note, that if your PC is really full of dust, you'll need the whole can to clean it. But it's worth it.
Hope I could help. If you have questions just leave a testimonial and I'll come back to you and help you with pleasure!
Jan 04, 2014 | ASUS Computers & Internet
Fix stuttering and pulsing fans
Clean them or replace them.
Mar 09, 2011 | Computers & Internet
Computer Beeps When Windows is Loading
First, you should be sure that the cooling fans are working properly. Especially the one that is on or directed to the processor. You'll need to open the system up to check this. Turn on the system and make sure all the fans are spinning fast. Now, check for lots of dust or dirt on the fans and processor heat sink. Most likely, the inside of your tower needs to be cleaned. If there is too much dust and dirt in the fans and on the processor heat sink, it can't cool itself and the system shuts down to prevent damage to the processsor once it gets to a certain tempature. I have seen this often. You will need to use a can of air on the fans and processor heat sink. There will be a lot of dust and dirt that will come flying up....which is good Then use a vacuum and a soft bristle attachment to get out the remaining dust. Put the system back together and you should be good.
Your manual should show you how to take the cover off your PC to access the motherboard.
I hope this helps you.
Apr 08, 2010 | Dell Dimension 8200 PC Desktop
The fan makes noise. how can I fix it?
Open the Notebook and Blow the air into the fan,this will get rid of dust contamination which is the main caused of the problem.
If the problem still persists,replace the fan.
Dec 28, 2009 | Toshiba Satellite A85-S107 Notebook
Overheatig of heat sink(or fan) due to dust accumalation what is the best way to get rid of this problem? is it possible to clean fan from the vent at the bottom?
no it is impossible to clean the fan from the outside you must open your laptop and remove the fan with the heatsink to clean the fan and please be carful not to break any thing
Oct 25, 2009 | HP Pavilion dv5000z Notebook
PC Fan Issues
1 fan in and 1 fan out, usually out through the front.
Aug 27, 2008 | Gateway 506GR PC Desktop
Computers & Internet Logo
David Payne
David Payne
