Question about LG CU500 Cellular Phone
Lg tu500f Brought a new lg tu500f on ebay. I can not get the battery to charge with 120v outlet charger or through usb port. Brought a new battery that has a full charge, but same problem exists. Where am I going wrong? Can you help? EC
  • 6,487 Answers
The problem is not the battery its the charging part of the unit, I also have this problem before that unit is nit charging , so what you can do for this is to take it to a celphone repair tech becasue they will need to check the charging part of it they may just solder it or replace thst small piece of electronic so it will charge again..
Hope that helps............
Posted on Aug 12, 2008
    Guru:
  • 1,894 Answers
This is not a problem with charger or battery.
some problem either with the metal contacts that hold the battery. else some other hardware problem inside the unit.
first manually inspect if all the contacts are fine wit out any loose connections.
thank you
  • dewan nafees ahmed Aug 12, 2008
    @ginko
    u speak about others place holding huh? lols..
  • LG Master
  • 19,396 Answers
You need to replace the charger
  • Ginko
    Ginko Aug 12, 2008
    Well, sorry I am re;reading the problem, if battery does not reach fully charge even using USB, and you replaced battery with a good one, then is a fault in the unit.
    If battery charge reach a good level I think you can still use the LG like this, if battery charge stays very low try to get a refund, the unit is faulty, probably a faulty component (capacitor etc.) in the battery charger side of the pcb inside your LG.
    Check also that battery contacts inside the slot are not covered with oxide.
BATTERY CHARGER IS THIS A SERPERATE ITEM
That depends on the camera.
Some cameras include battery charging circuitry. You plug the camera into a wall outlet or a USB port and it charges the battery. Some cameras come with a separate battery charger which plugs into a wall outlet or a USB port. Some cameras use standard batteries, disposable or rechargeable. With these you need to use a separate battery charger compatible with the type of batteries.
If you're asking about a specific camera, please add a comment to your question and specify the make and model of the camera.
Sep 24, 2014 | Cameras
I live in South Africa and my son has brought back a Panasonic shaver from the USA. Can our std 220v power outlet be suitable to charge the shaver? The power pack only mentions 120v input AC?
If the power supply that came with the unit says only 120V, you must use a voltage converter with the unit. If you plug the charger into your 220V system without a convertr, it will damage the charger
Apr 17, 2011 | Health & Beauty
How do i charge my camera so that i can explore
You can charge the battery in two ways.
Use the supplied battery charger. Remove the battery from the camera, put it into the charger, and plug the charger into a power outlet.
Connect the camera via a USB cord to a powered USB outlet. Be aware that not all computer USB ports put out enough current to charge the battery. You might want to consider a cell phone charger that plugs into a power outlet.
Nov 28, 2010 | Vivitar ViviCam 8025 Digital Camera
Ebay phone wont charge
while holding phone upright in you hand look on the side in the lower left corner - open the "tab" This is where you charge the phone with both a wall outlet & a car charger.
Mar 02, 2010 | LG CHOCOLATE VX8500 Cellular Phone
MY MOBILE PHONE CHARGING SOCKET HAS SNAPPED
You have 3 options when the charge port breaks.
1. get it repaired, warrant if possible
2. Get a new one
3. Get an external battery charger and charge battery separate from phone. Another battery and charger will set you back about 10 dollars on ebay.
For more information and links to the parts check the following link below.
Fix for Broken Charge port on Samsung SGH-D900
Mar 07, 2009 | Samsung SGH-D900 Cellular Phone
Battery charge
I agree that it sounds like you charger port is going bad.
The firststep is to contact your carrier to see if it is covered under warranty.If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.You can get an external battery charger to charger the battery separate from phone. cost about 25 dollars. Check out the following link for ones that are available on ebay. A extra battery is a good idea as well so you can have one charging at all times.
LG VU External Battery Charger Cradle
I hope that helps
Mar 01, 2009 | LG Vu CU920 Cellular Phone
LG shine wont charge
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
Jan 31, 2009 | LG Shine CU720 Cellular Phone
Lg env2 not charging
The issue is the charger port on the ENV2 breaks fairly easily.The first step is to contact your carrier to see if it is coveredunder warranty. If it is, great get it replaced.
3.You can get an external battery charger to charger the batteryseparate from phone. cost about 25 dollars. Check out the following linkfor ones that are available on ebay. A extra battery is a good idea aswell so you can have one charging at all times.
LG VX9100 ENV2 External Battery Chargers
Hope that helps
Aug 04, 2008 | Verizon Communications enV2 Cellular Phone
Vupoint dv-da1-vp in need of a battery and charger
Buy a "np-60" battery on ebay or other store. Some will come with a charger.
You can charge the battery via the usb cable from any PC or laptop.
Jan 26, 2008 | VuPoint DV-DV1-VP Camcorder
Sidekick 3 does not receive charge
All right. The Sidekick 3 has a known charging issue that crops up on some phones. If you are under warranty, call t-mobile and get it fixed. If not, the repair is going to run 100+ to fix the charging port.
A fast and simple solution is to by an external charger and an extra battery. They run about 30 bucks total on ebay.
Check out Sidekick Battery Chargers.
Be glad the battery is easily removable. The original sidekick and sidekick II had internal batteries that are a pain in the butt to remove!!!
Nov 07, 2007 | T-Mobile Sidekick® 3 Cellular Phone
LG CU500 Cellular Phone Logo
196 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
