Question about HP Photosmart 8250 InkJet Printer
ERROR OXC18A0001 INK SYSTEM FAILURE
HOW DO I CORRECT THIS? THANK YOU.
  • 2 more comments
  • Anonymous Dec 22, 2008
    same
  • sengaboyd Dec 22, 2008
    ink system failure
  • Anonymous Feb 09, 2009
    ERROR OXC18A0001 INK SYSTEM FAILURE problem,
  • JOHN Apr 23, 2013
    Ink System Failure Error: Oxc18a0001 getting this on a HP Photosmart C8180 all-in-one can anyone help ?
INK SYSTEM FAILED ERROR OXC18A0001
Posted on Nov 03, 2008
I go the answer from this web site http://www.fixyourownprinter.com/forums/printer/39471#13
Top notch.
Basically you do a reset by holding the OK cancel and black and colour buttons down and turning the device off. When you switch back on again it takes about 5 mins to sort itself out then it works - hurray!
Posted on Jan 15, 2009
Hi
I have a HP5260 Printer, and am having problems.
It won't print and gives error message: OXC18A0001.
The printer states "Ink System Failure, The ink system has failed and can no longer print. Refer to printer documentation. Error OXC18A0001 Turn printer off then back on,"
The online HP Product Assistant comes up with the message: "Print cartridge cradle is stuck."
I have checked for any loose paper, bur found none.
Posted on Aug 03, 2010
5 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: Ink System Failure Error: Oxc18a0001
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
adonscott
  • 106 Answers
SOURCE: Ink system failure
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer. Please let me know if the issue is not resolve so that i can check for a possible solution for that. Thank you so much. adonscott
Posted on Jul 05, 2008
SOURCE: HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Posted on Jul 11, 2009
Riztech
  • 731 Answers
SOURCE: My HP photosmart c7200 is showing System Ink
Please click the below link to find the troubleshoot information about this issue.
Solution Click here
Regards,
Riztech
Posted on Mar 08, 2010
HP 3210: Fehler Oxc 18a0001
The only way to fix Oxc18a errors is to reset the printer. You can find the instructions on www.inkbank.com.au website here:
HP ink system failure error HP maintenance error what to do if HP printer...
Jan 01, 2015 | HP Photosmart 3210 Printer
How to override error Oxc18a0001
If you have a C6180, the error code you give here is not in the manual, so you better contact HP service centre like the manual explains.
Jul 21, 2014 | HP Photosmart C6180 All-In-One InkJet...
I have error code Oxc18a0001- ink system failure. Can you help
Psil posted a possible solution 29 days ago; I repeat for your information:
just had this exact issue with my C7280. I called HP Tech support, got a body in Bangalore or someplace, and was pleasantly surprised that they were prompt and knowledgeable, and solved the issue very quickly after transferring my call one time to a hardware support expert.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
Jul 14, 2011 | HP Photosmart C7280 Printer
What to do hp photosmart c1580 series ink system
hat to do hp photosmart c1580 series ink system failure Oxc18a0001
May 01, 2010 | HP Photosmart C6280 Printer
HP Photosmart All in One error message Ink System failure -Oxc18a0001
There are N no of steps to be done so i am pasting the HP URL ,please follow it and u will get to some kind of solution in the end or u might have to replace the print head .
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&cc=us&lc=en&dlc=en&product=3560280
All the Best
Feb 17, 2010 | HP Photosmart C5180 All-In-One InkJet...
Hp photosmart d7200 erro Oxc18a0001
Filling your cartridge with non-HP ink won't cause an error. There are basically two reasons for ink system failure, The cartridge is no good or the ink system has failed. Some of these machines can be reset. But, try replacing cartridge first.
Jul 16, 2009 | HP Photosmart D7460 Printer
Error message oxc18a0001 ink system failure
Go to HP website, I recall some info there on this
Apr 25, 2009 | HP Photosmart 3310 Printer
Dec 04, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
Jul 01, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart 8250 InkJet Printer Logo
2,993 people viewed this question
Ben Johnson
