Computers & Internet Logo
Anonymous Posted on May 08, 2011
I bought the behringer UcA202 audio interface for acid music studio 8.0 The interface comes on but when I plug it in to the USB the audio doesn't enter the USB why won't it hear the audio through the USB
Anonymous
Level 2:
Novelist:
  • Expert 82 Answers
  • Posted on May 08, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
82
Questions
0
Helped
17164
Points
227
To hear audio through the USB, you have to go into your control panel and change the audio output to the Behringer interface. (It may be specific, or it may just have a generic "USB Audio" option.)
  • Anonymous May 09, 2011
    Thanks really happy I need to disable external mic for it to pick up USB.
Hi iown a sony- mds je 330, how can i transfer from md to computer?
Sony has a free program called Sonic Solutions. It stinks to high hell. But it is free.
I strongly suggest you either play the MDs into your computer via the LINE IN, or buy a Behringer UCA202 USB Audio Interface from Amazon for $30 and input the audio digitally via the USB.
That's how I do it.
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
How do you connect behringer sx2442fx eurodesk sttudio mixer on acomputer in studio
WIthout a quality audio interface the answer is you don't... You need to procure an audio interface for the computer. The internal audio systems of computers are too noisy to get decent results. The manual for the mixer will show the typical studio connection with a suggested audio interface.
I have a problem with my behringer b3031a truth studio monitors.Slightly before a sound it's played (and during the playing) they make a little buzz. Ex. I turn on Windows Media Player and as long as...
The fault is not with the speakers... It is with the noisy audio system common in computers. Get a decent USB audio interface and use balanced interconnect cables to solve the problem.
I have just got a Behringer uca202 usb interface, have wired it all up correctly and yet some how there is HUGE static noise when recording and playing back in my monitors/headphones, the monitors are not...
Two things... Make sure echo function is off and ALSO that ALL equipment is powered from the same receptacle to insure no ground loops.
One other thing is to make sure all anti-virus and other background programs are idled while recording. Even things like wireless LAN running can interrupt the smooth flow of data from the device.
Hi.I just want to know if my Behringer UCA202 can give me professional sound in my home studio.How professional is it? Thank you.
It is a low cost alternative. It can be used as an interim choice until you get a true audio interface tailored for a recording studio. I use them to connect to my laptop for recording group mixes for live performances on a bus mix. It works well for that type of application. It has quality sound recording and playback at CD quality.
There is a weird sound when i try to record something with my U-CONTROL Behringers
If you are trying to record from your turn-table make sure your earth wire is connected to the USB device as per hook-up instruction, this should eliminate any buzz sound your having.
2answers
I need halp how to plug up my behringer eurorack mx 3242x to my pc
Have a look at the Behringer UCA202. Its a Usb port that should help you do what you want.
Don't know how to record from cassette deck to computer
here is the link for Behringer
this is the user manaul for UCA202
this should help you find what you need.
http://www.behringerdownload.de/UCA202/UCA202_ENG_Rev_B.pdf
No Real Time Sound from USB Port in Headphones
The problem is due to the design of the DELL Laptop itself. It is not dsigned to monitor the incoming signal. I bought a cheap Behringer UCA202 USB-Audio Interface. It provides for real time monitoring the incoming sound. I can also hear the accompanying music while I play along with pre-existing tracks. It's not the highest quality but it was only 25$ so well worth the price.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
