Question about Sony KP-65XBR10W 65" Rear Projection Television
KP-65XBR10W Flash of Red!!
After on for awhile the set flashes red then turns off. I had an issue about 1 year ago where red lines appeared. I adjusted the voltage to remove these lines. Now the screen flashes red and then shuts off, goes to stand-by. The lights do flash but I am not sure how many times. Do I need a new CRT? If so are they available?
  • ccdsmith Sep 05, 2008
    kp65ws500, actually, and the color is green, but exact same issue otherwise!!
  • 320 Answers
It sounds as though both of you have intermittent shorts in the picture tubes which I have seen before. Unfortunately, due to the age of the units and the likely scenario that you will be looking at relacing the other CRT's, it is probably not a good investment to repair the sets. If you are still interested in repairs, there are places that will rebuild the CRT's, but I believe the original parts are no longer available. If you found this solution to your liking, please be sure to rate me. Thanks.
Posted on Oct 22, 2008
I have a Sony KP-65XBR10W 65-inch HDTV - green flashes shut down
Most likely you have a Green CRT that is failing. Sony no longer stocks the CRT assemblies for most of the older Projection sets. Instead what is required is to send the Green CRT assembly back to Sony (minus the Delta Lens), so they can replace the Tube on the Optical Coupler. This is a major cost of about 400.00 to 500.00 for the CRT plus the the tear down and reassembly time. Then you need to do a major Convergence alignment because the other two CRTs are aligned to the Green CRT. Due to the cost and the fact that Sony will not be supporting the older sets much longer, I would not invest the money into it.
I hope this helps,
Skyassoc
Feb 09, 2010 | Televison & Video
The screen has green flash then powers it;s self off after 10 seconds
the green CRt is shorting you need to replaced it problem is the crts are no longer avail time to think about retiring that set
Dec 22, 2009 | Televison & Video
Screen had red/orange lines, then the screen went all orange
your read crt is shorting out sorry to say the crts are no longer avail, you can have them rebult but on a projection set they will never look good due to phosforous burn I would say it is time to retire the set
Dec 11, 2009 | Sony KP-65XBR10W 65" Rear Projection...
RED SCREEN
hell yeah,
the biggest mistake I did with this tv.all tubes need to be replaced and it burns a hole in ur pocket.no guarantee on tubes,sony aware of the problem but didnot recall these defective sets.
good luck.
nanz
Oct 27, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-65XBR10W After awhile, shuts off
It sounds as though you have an bad blue CRT. Due to the age of the unit and the likely case that you also have weak green and red CRT's, based on the age, it would probably not be a good investment. Please be sure to rate my response if you found it helpful.
Oct 22, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Red Shadow
UNDER THE FRONT DOOR PRESS THE BOTTOM BUTTON "FLASH FOCUS" AND SEE IF IT FIXES IT. IF NOT AND YOU SEEN RED DOUBLE OF THE IMAGE, THEN THE SET PROBABLY NEEDS THE CONVERGENCE CIRCUIT REPAIRED.
DON.
Feb 01, 2008 | Sony KP-51WS510 51" Rear Projection...
Bright green flash and red arching lines
You need to check the bulb in the back of the set as it could be on the way out . just check to see if the bar in the bulb has gone black as it is a good sign the bulb is on it's way out . the bulbs only last 2-3 years or 4000 hours . If thats ok you most probaly have dry joints on the tuner , they just need resoldering
Jan 29, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony kp-65xbr10w led light blinks 5 times
i have a sony tv model kv36fs17. led flashes 5 times. tv works but no red color. would could be the problem? thanks
Jan 23, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Sony KP-65XBR10W 65" Rear Projection Television Logo
65 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
