LG Intellowasher wd1280fhd door jammed - Washing Machines
  • mc_photograp Aug 13, 2008
    The lock was broken and a replacement has been ordered,while the advice given did not specifically cure the problem,the investigation of the possible causes led to finding the fault.
    Thanks
    Guru:
  • 1,894 Answers
Door jammed error or door itself has got jammed really?
are you trying to open the door in middle of cycle of after full completion of cycle?
Posted on Aug 12, 2008
  • dewan nafees ahmed Aug 12, 2008
    There are safety devices that prevent you opening the door or lid while the
    washer is spinning or agitating. This is for your protection, so don't
    circumvent these safety devices.
    There are many reasons why the door may be jammed shut -
    1. The water hasn't pumped out properly and the washing machine has a
    pneumatic door safety lock (a rubber hose connected to the door
    interlock and connected to a pressure chamber bottle on the tub - water
    forces air up this tube and locks the door)
    2. Washing machine won't empty water
    3. The water has pumped out properly, but a blockage of gunge inside
    the pressure chamber bottle is trapping the air that's operating the
    door lock (if a pneumatic lock is fitted - not many have these days due
    to cost cutting)
    4. Door interlock jammed
    5. Door catch, handle, or mechanism broken
    6. ****** (a device that detects the motion of the drive belt fitted to
    many older Hotpoint washing machines which "pecks" at the belt when the
    door handle or button is operated) is broken or has fallen off
    Do not take the lid off and reach inside the washing machine to try and
    release the door if the washing machine is still plugged in as you will
    be electrocuted.
    I would try to run just the spin cycle again. If that doesn't work, it's time to call the repairman.
    thank you
WD-8050FH, LG Intellowasher washing machine, front door gasket is twisted. What is the likely cause?
Broken spyder. The three arm hub that attaches to the inner tub. It is replaceable. Open door and wiggle inner tub. If it moves inside of outer tub, that's a sure sign.
Oct 01, 2017 | LG Washing Machines
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
DEL--repeatedly does not sense door closed to lock and start
the door door catch striker is worn replace it and then try you should be able to buy on line quite cheap
Oct 02, 2012 | LG Washing Machines
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
What does OE mean on my LG intellowasher frontloader
its a open door error its because the door is not closing all the way.
Dec 27, 2010 | LG Washing Machines
LG Intellowasher (Model WD-1023C)
The water pump can be blocked and thus stop the machine from finishing the wash cycle. In front on the bottom there is as hatch that can be opened with a flat screwdriver, the small black rubber pipe can be used to first drain all the water before the opening the filter. Small objects such as coins coluld be found in here, blocking the pump. Clean the pump by removing these, optionally blowing into the outlet (yuck!), to dislodge anything. If that does not help to fix the problem, you can clean that actual water pump, but this requires you to use a screwdriver to remove the pump.
Tilt the machine on its side, the pump is attached with 3 self-tapping screws. (if you can't figure out what the pump is you should probably let a technician do this). The pump has 2 parts to it, take it apart carefully and clean out all the dirt that has accumulated in there. Plastic friendly, waterproof grease can be applied to the pump spindle and bearing if available.
If the problem still persists a new pump is available from LG at a reasonable cost.
Jul 30, 2010 | LG Washing Machines
LG INTELLOWASHER DD 7KG DOOR LOCK STAYS ON WAY TO LONG
Never heard of that; I would try a new door latch as I have never had a bad control issue with the operation of the door latch. There is no real way to test it. I can getb you the latch if interested. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 29, 2008 | LG WM1814CW Front Load Washer
My LG intellowasher DD WM1480 FDH washer displays DE (door open) and refuses to start, if I repeatedly open and close door sometimes it will start or the door will lock and it still doesnt start.
I have this problem too for my LG Intellowasher. I suspect it is because you're selecting "Rinse Hold" from the options. Try turning the power off and washing again on another setting to see if this resolves the issue.
May 03, 2008 | Washing Machines
Washing Machines Logo
156 people viewed this question
Top Washing Machines Experts
