Samsung SyncMaster 240 T 24.1" Flat Panel LCD Monitor Logo
Posted on Aug 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Green line vertical on screen keeps appearing
This line appears after about 10 minutes and will not go away until after you shut down for an extended period of time. The line is green in color. Its a samsung hdtv monitor 24" with 1080P and 1920 x 1200 resolution.
  • jbruno Aug 12, 2008
    the line is vertical and goes top to bottom on the screen and is green in color. It is a thin line.
Anonymous
Level 3:
  • Master 983 Answers
  • Posted on Aug 12, 2008
Anonymous
Master
Level 3:
Answers
983
Questions
8
Helped
434523
Points
2838
In the monitor menu button you will be having a option called "degauss" give that when it appears ...
if you still persist the same problem then there may be some problem in the CRT tube ....
just take your monitor to the technician ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution
2answers
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
White vertical lines like jail bars
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
1helpful
Thin green vertical line on rhs of the screen
Likely the panel is bad. If it's not covered by your mfc warr or you did not buy an extended warr then replace the tv. the panel is more expensive to replace than a new set.
2answers
New lcd installed in satellite l505, started out fine, as it warmed up a single vertical line appeared about 3 in from left, will occasionally disappear, but comes back in same spot after a few minutes,...
Yes, this unfortunately is the beginning of the end of the LCD screen, you see the "Driver Circuit Transistors" are starting to go faulty... this is a very common problem, occasionally, it may be the Video card, you will have to "monitor"...(pun intended), the situation. If it continues, as I expect, and lines appear down across, the screen that never go away, and are RED or BLUE or GREEN, then it is most definitely the LCD itself, if however they go away come back in differing places, then it is more likely the Video card. replacement is the only fix sorry. I would wait until it is unbearable before you do anything.
36helpful
6answers
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Strange Green Vertical Line
I encountered a problem with my sony vaio laptop after installing windows xp. It lost sound and keeps reporting that it does not have sound device when i try to play music.
2answers
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
