Stoves Newhome ECH600MXa Electric Kitchen Range Logo
Posted on May 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Got stoves double oven, oven not heating up - Stoves Newhome ECH600MXa Electric Kitchen Range
Anonymous
Level 3:
  • Stoves Master 43,501 Answers
  • Posted on Aug 13, 2011
Anonymous
Stoves Master
Level 3:
Answers
43501
Questions
0
Helped
10842319
Points
101584
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 =-
Oven will not heat past 195 degrees
Check and see if you have blown a fuse which is usually in the top of the stove in the area of the clock if you have one. You usually can get in from the back of the stove at the top.
2helpful
My double ovens do not work unless I keep the buttons pressed in the whole time I need for cooking, when I let go the ovens go out?
YOU NEED A NEW CONTROL MODULE, THAT PANEL IS A COMPUTER BOARD AND DOES BREAK. EITHER FROM HEAT EXPOSURE OR CLEANING SOLVENTS
Just moved, can not get stoves double oven to work light and fan comes on both ovens but no heat
On the main oven, does the circulating fan at the back of the oven start to rotate when you switch it on and does the fan oven neon illuminate as well.
For the top oven, the heating element is not very big so the oven takes a long time to warm up. Does the top oven neon illuminate when you switch this on as well?
Main oven not heating up , fan running ,temp light on but no heat
I suspect that the oven element has failed, to check this, remove cover at rear of oven compartment, there you will see the round oven element, it should feel hot after turning oven on to heat, if it is cold, replace it.
Fes330 roper stove power to stove ...ok no fault codes on display normal "stove on" lites....ok normal appearance except no heat from 4 eyes and oven below
you have no heat at all? K, pull stove out and check how many volts you have should be 240. Your elements work off 240 if you only have 120 coming to stove the lights will work jujst not your heat. You should have a double pole 40amp breaker If you only have 120 change the breaker
Oven not heating
I know waht is wrong and I sell the solution.
Thanks!
email me at: [email protected], if interested.
Neff model U1461
your convection element has blown by one online and replace it yourself
2answers
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at [email protected]
Oven and Stove top don't heat up but indicator lights on
there may be power but is it enough power??? if electric oven oid check you fuse box/ circuit breakers and physically reset the double breaker controlling the stove, perhaps one leg of power has dropped out
Mar 17, 2008 • Ovens
Top Stoves Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
vince
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
