Question about Canon Office Equipment & Supplies
I needed a wireless printer for my laptop. My husband gave me a Canon Pixma ip2600. It doesn't look like what I had in mind. I would keep it to print photos but it loos like it only does up to 4x6. Is that all correct?
    Master:
    Sergeant:
  • 398 Answers
Type brand and model into google, and you will learn all you need about this critter.
Posted on Aug 12, 2008
SOURCE:
Pixma iP2600 Photo Printer InkJet: Canon iP2600 error codes...
my printer will not print out anything. it starts to but the paper never enters into the printer, it is almost like it is jamed but it isn't.
The message says there is an error, push resume and try again.. same thing, it starts to push paper thru.. acts like a jam.. same message.. but paper is not jammed
May 16, 2010 | Canon Pixma iP2600 Photo InkJet Printer
My canon ip2600 printer has a paper jam error, but there isn't.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 23, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Am si eu o probleba cu o imprimanta Canon PIXMA ip2600 imi da o eroare tip de "5100"
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Mar 23, 2010 | Canon Pixma iP2600 Photo InkJet Printer
How to replace ink cartridges in ip2600
Hi
Not sure if you not got the manual.
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/HP-Manual-ip2600_EN-US_V1.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Feb 05, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Connection to laptop
Most printers are connected to laptops via the USB ports. If the printer is supposed to be wireless, then you may have to connect the laptop via the USB port so you can activate the wireless port.
Don
Nov 23, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Canon ip2600 reset problem, when i change the cartridge sin my printer the ink levels dont reset and it stops printing can any one help me with how to reset the ink levels please
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On most printers this happen with push resume button and hold it for 5 seconds.
The printer shows empty cartridges but it will printing.
Oct 19, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Will iP-tool.exe v.1.1.5 reset my iP2600 ink levels to 100%
Yes it does reset ink levelsas well as do several other things very well.....highly recomend the program for an ip2600
May 13, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Open Questions:
Clive
Clive
old marine
old marine
Ekse
