Question about Fujitsu 24C1 Air Conditioner
Want to replace our old furnace with heat/air(split unit)we think.
Please help us with any information possible as I haven't found anyone or any info. on these units to help except one guy wanted 4800 dollars to put one in for me. We are on fixed income. please Help. Thanks! Rachel
  • 3 Answers
Well i don't know you live but i live in iowa and the here you still will need a furnace because your air to air heat pump is only good to about 20 deg. that is where i have mine set any colder out side and i cant pick up enough heat from the outside to heat my house. but what i did was just put the heat pump on my old furnace so it will run on the heatpump till the temp get to cold then goes to the gas furnace this way you should cut cost down by using the old furnace for the blower and just replace the indoor coil and the condenser outside. they have t-stats now that will do all the brain work for the heat pump (switching heat sources) also you might try to find someone who installs goodman i have installed quiet a few of them and they are a good value for the price
Posted on Jan 24, 2009
Bought a house with Lennox G12Q3-82-3 furnace. It doesn't look like electronic ignition. A sticker showing AirMedic Electrostatic Air Cleaner says it was installed 10/1992. Doesn't work.
Here's some borrowed info.:
`These are classic symptom of a limit switch opening. Can't guarantee that is what is going on, but here is some things that can cause the limit switch to open:
1) Low air flow. This can be caused by dirty filter, dirty blower wheel, dirty air conditioning evaporator coil, restricted or collapsed ductwork, blower motor running the wrong direction, blower running on too low of a speed, defective limit switch, or a combination of several of these factors. Inspection along with measuring the temperature rise will find most of them.
2) Heat exchanger failure. Split or burned through heat exchanger
3) Over-fired furnace. If you have eliminated everything in section 1 and 2, and the temperature rise through the furnace is still high, you need to check the furnace to make sure it is not burning more fuel than it is designed to burn. If it is a natural gas furnace, you can check the amount of fuel that is being burned by clocking your gas meter.
Here is a link that will tell you how to use your gas meter to calculate the BTU input of your furnace. It should never be more BTU than the furnace's rated input.
http://www.bacharach-training.com/referpage/clocking_gas_meter.htm
The problems you have could be potentially hazardous. If you are not able to aggressively find the problem on your own, you should hire a professional to look at the furnace immediately. The G12 furnace is getting relatively old. If you have never had it professionally inspected (sounds like you haven't), you probably should have a professional look at it immediately.' END QUOTE
This might cover your problem? don-ohio (:^)
Dec 19, 2016 | Heating & Cooling
I have RUUD furnace with build in coil for air conditioner and Weather King compressor outside of my condo. ALL EQUIPMENT IS 4 YEARS OLD I didn't have any problem with heat at winter, but in summe
When you remove the panel to the unit it turns off the power to it. The reinstalling the panel will reconnect power and allow the unit to reset. So the cheapest and easiest thing you can try is to replace the thermostat. Make sure you see how many wires you have connected to your existing tstat and buy near the same thing. It's possible that the tstat is acting up, not allowing the unit to cool when the temp demands. And turning off power is resetting the tstat as well as the unit. It will be hard to troubleshoot with the info provided so a new tstat will be worth a shot. Hope this helps!
Apr 07, 2017 | Ruud Matching Split Air Conditioner
Replacing a Coleman with a Duotherm, can the same thermostat and controls be used?
Hi, yes you can use the same thermostat if you are replacing the unit that has the same sequence of operation. What I mean is, if the old unit is a gas fired furnace and outdoor condenser split system for the a/c you can use the same controls, or if its a package unit. Now, if you are installing a heat-pump unit in place of a gas fired central unit, you will need to pull more stat wire and buy a heat-pump thermostat to make it run.
Shastalaker7
A/C, Heating Contractor
Oct 12, 2010 | Coleman Mach III Air Conditioner
M/n 38brb060300 carrier
Hi, to tell if your unit is a heat-pump or not, if the indoor unit is not gas fired, it is a split system heat pump. If it uses gas or propane gas, its a split system gas/elect unit. Look at your thermostat also. It should have aux heat, emergency heat on it also. Maybe not both, but you will know if you have a heat pump. Please don't forget to rate me. Please be kind, as I know you will. Just remember, no gas, its a heat pump, gas fired furnace indoors, its not a heat pump.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Jul 15, 2010 | Carrier 38CKC060 Air Conditioner
Bryant-Carrier Furnace Fan Stays On
I suspect a bad fan relay or bad fan control. Maybe the longer the control or relay is in the on position the more chance of it sticking on.
Oct 17, 2009 | Bryant 462AJC021BA Air Conditioner
Central a/c compressor has failed. Approx. 9 years old.
Info is somewhat incomplete, but here is what I think.
If you just want to replace the compressor, that amount should cover it or at least be real close. But, if the unit is, say, over 10-12 years old, you may want to replace the entire unit. The issue then becomes very expensive. The new laws now make it a requirement for manufacturers to produce nothing under a 13 SEER rating. This has really driven up the cost. Plus, you may have to replace the indoor coil to match the new outdoor unit in almost every case. Then you have to look at the air handle to see if you have enough blower to move the correct amount of air over the new coil. If not, then a new furnace and blower is required.
I know this sounds like way too much information but, you asked and I feel you need the complete picture. I'd get it checked by a tech and ask for 2 senerios, repair exsisting, or replace and upgrade system.
Good Luck and hope this helps.
And congrats on your new home. Hope you enjoy it.
Jun 10, 2009 | Heating & Cooling
Ruud Furnace needs replacement
What part of the country?
How many square feet in the house?
Insulation?
Single pane glass?
Many factors should be considered by a professional.
However if the old unit worked OK, a new 80% 70,000 unit will most likeley replace a 24 year old 60-70% 75,000 unit.
Dec 14, 2008 | Carrier 38CKC042 Air Conditioner
I need to know what size central heat and air unit i need for my house
Absolutely, can you give me the following info?
Do you have ducting? If so how many vents? How many return vents, and what size? How many square feet do you have to heat and cool? Are you replacing an old unit? If so whats the old units model number and make? Are you buying the Heat Pump, gas furnace, electric furnace, or dual fuel, or Air conditioner?
Thanks a lot of questions, but extremely important in sizing your home.
Dec 08, 2008 | Heating & Cooling
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Dec 03, 2007 | Honeywell CT3200 5-2 Day Electronic...
Fujitsu 24C1 Air Conditioner Logo
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
