Question about Panasonic Workio DP-2500E Copier
Faxes coming in sideways
When we receive a fax it comes in legal instead of letter so it is taking two pages.
  • clarissabout Feb 05, 2009
    fax is coming out sideways
  • 100 Answers
1 solution that i can advice you is that there is a fax setting ( in the fax parameter setting - function 7 - 4) which is about auto reduce all incoming fax to a4 or letter size.
Posted on Aug 22, 2008
When receiving large faxes, it prints a blank page (numbered in succession though on the top as __ of __) in between each page of the fax. How do I stop this?Canon LaserClass 9500 -- When receiving l
What size paper is set as default on your end? If legal size, that may be why. Also- how quiet is the telephone line? If it is getting interference from a close proximity flouorescent light, or just noisy, it may be the noise being interpretted as a new page break.
If it is set up to autoselect the page size, look at noise as a possibility. If it is only a random occurance, it may be as simple as the paper itself sticking together slightly, (if it sticks together on the other end, there is not much you can do about that.) or the pickup feed may need the rubber tires cleaned.
If it only happens from one or two numbers and not others, it is likely line noise on either end. On your end, you can install some ferrite beads to reduce it, if on the other end, they will need to do it.
Apr 11, 2012 | Canon Office Equipment & Supplies
Faxes sent to other parties come out on two pages instead of one page
Clean / Change or Adjust (little lever) the seperation pad in the original feeder
Your documents are partially double feeding or steam feeding causing the machine to think the page is longer (81/2 x 14) instead of letter
The seperation is a small flap of rubber or a roller just clean with soap and water. and a damp cloth
Apr 06, 2010 | Samsung SF-560 Plain Paper Laser Fax
CAN THE MEMORY BE LEAGNTHED ON HP1020 TO HOLD IN MEMORY MORE FOR INCOMING FAXES OR ELIMATE HOLDING RECEIVE FAXES AND PRINT PAGES AS THEY ARE RECIEVED INSTEAD.
I found the manuel on line and found out how to print the faxes in memory to release the memory. So next time a big fax comes thru I will try to print and release faxes from memory.
Nov 13, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printing blank pages when receiving fax
Ask if the ones sending are sending legal size, it may be using 2 sheets to get all from a legal size document.
Jul 29, 2009 | Brother MFC-8460N All-In-One Printer
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Letter sized fax page overlaps onto 2nd page
Change your faxes DEFAULT font size to a lower setting... lt us know if it still does the same thing for the same amount of characters
Nov 09, 2007 | HP PSC 1510 All-In-One InkJet Printer
FSending and receiving faxes on legal size paper.
Press Menu/Set, 1, 3 Press up or down arrow to select Letter, A4, A5, A6, B5, B6 or Executive Press Menu/Set Press Stop/Exit :o)
Apr 20, 2007 | Brother IntelliFax-2820 Laser Fax
Fax received printed sideways, 50% size
If its not constant its probably on there end. Does it happen with any other party. Lawrence
Nov 20, 2006 | Panasonic Panafax UF-790 Plain Paper Laser...
Panasonic Workio DP-2500E Copier Logo
121 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
