Question about Kenmore Elite 45986 Front Load Washer
Kenmore he3 series washer keeps filling with water when not in use
How do i replace my inlet valve. is it simple enough for me to do?
my drum on the Kenmore He3 keeps filling with water when not in use
thanks
j
  • 1 more comment
  • Anonymous Oct 13, 2008
    yes, my washer too is filling up with water. A constant stream of water is flowing into the drum from the rubber water inlet area. Is this a valve problem or what?
  • ckirk1968 Oct 13, 2008
    I have the same problem. There is a constant trickle into the drum from the upper left water outlet on the inside. Water will gush out if I don't hit drain/spin prior to opening the door.
  • Anonymous Dec 22, 2008
    I also notice a puddle of clean water when I go to do the next load of wash. It appears to be trickling down the rubber membrane near the door. Should I leave the door closed or open while waiting for the next load?
  • 127 Answers
Remove the 3 screws at the back of the machine that hold the top on. pull back on the top and lift the top off. Remove the hose from the inlet valve and remove the screw that holds the inlet valve.
Posted on Dec 23, 2008
SOURCE:
Sears washer elite he3 fills back up with water when off
You have to shut your wall inlet pipe after your wash is over. If the leak persists you only have to change the inlet valve, which you can do yourself, see internet for spares quoting your washer number, model. It is good to keep the valve closed when the machine has finished it's wash.
For unlocking hold down "end of cycle" button at right side of panel for 3 - 5 seconds. The door remains locked when there is water in the machine, it does not want to wet your floor. Today's machines are smart. Helped?
Mar 05, 2013 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My kenmore elite HE3 washer keeps filling up with water
This problem is commonly attributed to a water inlet valve leaking by or a pressure switch malfunction. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
If you live in an area that has hard water, or if you use well water, the water inlet valve can clog with sediment, rust, or calcified deposits over time causing the valve not to close properly. This can cause leak by when not in use.
The pressure switch has a small air hose attached that, if it has any holes in it, will cause the pressure switch to malfunction. This can also result in a washer that fills when not in use, but will also cause the washer to overfill in most cases.
Read through the link provided and let me know if you need further assistance. I have included parts resources and procedures on how to replace each part in the link. If you have any questions, please post back and let me know. I hope this helps you.
Jul 11, 2010 | Kenmore Washing Machines
My Kenmore HE3 is leaking within the washing compartment.
The problem is commonly caused by either a pressure switch malfunction, or a bad water inlet valve. The way you can tell is to leave the water turned on and unplug the washer. If the water continues to flow, the problem is the water inlet valve. If the water stops, the pressure switch.
To access either component, you need to remove the top panel of the washer. Locate the three screws that hold the top panel in place and remove. With the screws removed, the panel will slide back, then lift off. The water inlet valve will be loacted in the left rear of the washer (as viewed from the front). The pressure switch will be in the rear on the right.
To replace the water inlet valve, follow these steps:
1. UNPLUG the washer.
2. Turn off the water source and disconnect the fill hoses from the back of the washer.
3. With the top panel removed, disconnect the dispenser hose(s) and electrical connections to the valve.
4. Remove any mounting screws holding the valve in place and reinstall with a replacement valve.
The pressure switch is even easier. One connector plug and an air hose is the only thing attached to the switch. The switch is usually snapped in place along the interior cabinet wall with no screws holding it in place.
Replacement parts can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare. The first three sites on the list also include helpful exploded view diagrams of your washer to help with locating parts and assembly.
I hope I've given you enough ideas to work with in narrowing down the cause of your symptoms. This is generally a very simple repair, that isn't very expensive. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Nov 28, 2009 | Dishwashers
My HE3 washer fills up with about 3 inches of water on its own when it is not in a washer cycle
Fill valve is not sealing correctly when it is switched off
If your machine is hot & cold fill, try turning off the cold water at the inlet and see if the machine still fills up if it does then it is a faulty hot valve if it does not then it is the cold one
They are easy to change and easy to buy from dealers or third party suppliers
Jun 19, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front Load Washing Machine Filling On It's Own
the inlet valves are shot. what happens the coils in the inlet vales can no longer hold the water from going into the unit, causing water to run into unit when not in use. replace the inlet valves and you should be good to go. the inlet valves can be removed by, removing top panel(3screws in back), disconnecting hoses, taking the small clamp on the small hose connected to the dispenser. theirs a small screw holding the inlet valves from back pane, remove old inlet valves and replace and you should be all set. hope it helps.
Apr 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 washer
The water valve is not closing fully. You will need to replace the water valve.
Mar 31, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water seeps into my Kenmore Elite HE3 washer went is not in use. Does anyone else have this problem?
You are going to have to replace the water inlet valve. Since it's filling after the end of the wash the pressure switch is not going to detect the fill. The valve is not closing properly. It's an easy fix, remove the top and the valve is right there, te part number i think is 8181694
Mar 18, 2009 | Kenmore Elite 45986 Front Load Washer
Water Building up Inside Front Load Washer when not in use
Okay, it is normal to hear water sloshing around inside the wash tub when the washer is not in use. A small amount of residual water remains in the wash tub under the wash basket (stainless steel tub), and resides in the drain line and drain pump. That's why it is important to keep the door slightly open when not in use to allow the drum to air out. The water will not evaporate, but it will help reduce the build up of odors, mold and mildew.
Now...if your washer is slowly accumulating water in the wash basket area over time, your water inlet valve is probably starting to fail. The leak can be very subtle and you may not notice it. The water only comes from one source - the fill valve via the dispenser. If you wish to replace it, the part is available at searspartsdirect.com. Just type in your model number and the part you need can be found under the "Dispenser" heading as item number 1. The replacement is very simple if you follow these steps:
1. UNPLUG the washer and turn off water supply.
2. Remove both fill hoses.
3. Remove the top panel of the washer by removing the screws that hold the panel in place in the rear of the washer.
4. Slide the top panel back, then it lifts off.
5. The water inlet valve is located in the left rear of the washer as facing from the front.
6. Remove the rubber hose leading from the valve and the electrical connections.
7. Remove the mounting screws holding the inlet valve in place.
8. Re-install new valve using these steps inthe reverse order given.
I hope you find this information helpful. If you have further questions, please post back and let me know.
Jun 06, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
895 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
