Question about iLO DVD Recorder DVDR05
Dvd player and analog tv
I am using an analog tv with convertor and rabbit ears, can't get the dvd player picture to play
Tengo un dvd ilo y un control remoto ilo pero nesecito los codigos para programarlo y que me digan como se hace .. Gracias.
Posted on Nov 06, 2012
Make sure you hook antenna to convertor box, not ILO, then hook the a/v outs from box to a/v inputs on ILO, then ouputs on ILO to the inputs of the analog tv.(video or channel3/4) Select Source on ILO remote and then choose the a/v inputs you have box hooked to.(make sure you have the three that highlights during this process and not have them on two different sources-getting Audio on one source or picture on another- easy to get them mixed up)
Posted on Aug 26, 2008
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Posted on Aug 13, 2008
No reception with rabbit ears
Check to see if you have the "Rabbit ears" plugged into the correct spot and you are on "Analog tv" if you are trying to use digital tv on "Rabbit ears" it can't send out a strong signal like the areal ontop of a house. You may need to get an adapter to broadcast a stronger signal but even better if you can connect to roof antena.
Oct 24, 2012 | Panasonic TH-42PX6U Plasma TV
I have a Magnovox video cassette & dvd player combo, model # DV200MW8. I have an RCA analog TV with 1 cable port in the back and 3 RCA jacks ports. Previously, my Maganavox VCR/DVD player was connected...
omg , haven't heard the word VCR in decade.
are you kidding? seems not.,
what's next 8track tapes? and Beatles? LOL ! "hard days night?"
omg 2, rabbit ears,, im blowing out a gasket laughing...
vhf/uhf analog tv is gone. now. (FCC rules ,dead) HDTV sure.
please say what you are up to the job.?
are you trying to burn VHS tape to DVD? nah.... that be me 16 years ago.... then gave all my VHS away at work. hated VHS, ugly mess.
i see, says the blind man!
you need a switch box.
yes, they still sell them like on ebay but not walfart.
Mar 13, 2017 | HP Compaq Presario V5204nr Notebook
No antenna signal nor found channels for my area.
You'll need a better antenna to solve your problem. With the new digital broadcasting, signal strength is everything. With analog, a weak signal would give you a watchable but fuzzy picture. A weak signal with digital gives you nothing, or possibly a picture that freezes up or breaks into blocks (pixellation). The only cure is a better antenna, either an amplified indoor antenna or something outside.
Sad to say, there's no guarantee that will work. If you live too far from the station, or have hills, buildings or other obstructions that block the signal, you just may not be able to pick up some channels. In some areas people have found they get no reception at all.
At www.antennaweb.org there's a tool that will tell you what stations are around your area and how far. It's designed to help you figure out what kind of antenna you might need.
Jun 15, 2009 | Insignia IS-PDVD10 Portable DVD Player
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
iLO DVD Recorder DVDR05 Logo
286 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
