Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
Cleaning my philips 51 inch
I havecob webs between the screens there is a spider there
I had a spider also, take the screws off the upper back cover, there are around 10 screws. The lens, mirror and screen are now visible. I used a vaccum to get my spider out.
Posted on Aug 12, 2008
SOURCE:
51" Philips Projection Wide Screen. Want to know
Almost all the Philips projection sets have a large black plastic shroud on the top half of the back of the set----it can be removed--most of these sets use torks type screws (star shaped).
With the upper part on the back removed you will find the mirror is suspended---do not try to clean it--it is film like handy wrap and will not need cleaning.
I use a swiffer type duster to reach inside the set to remove any spider webs etc, If dead insects or dirt inside the screen use a very soft cloth with water (just dampen the cloth slightly)
Usually you are seeing spider or cob webs and the duster will get them all--DO NOT APPLY FORCE IF YOU WIPE THE INSIDE OF THE SCREEN AS IT IS EASY TO SCRATCH IT!
If this information helped you, rate this solution as I do this here for free.
If you have questions make a comment here and I will do my best to answer them.
REGARDS, SD TECH
Aug 18, 2010 | Philips Magnavox 27MS343S 27" TV
I have spider webs on the inside of the screen on my hitachi 51G500. How do I clean them out?
you can unscrew the back top using a screw gun probably a long philips driver. the bottom of the tv is where alot of the unsafe things to touch are just focus on the top
Jan 03, 2010 | Hitachi 51G500 51" Rear Projection...
I have Toshiba 51H84 rear projection HDTV. There
Open the tv up,but don't touch the lamp use a fan open it high setting blow out everythings should clean it.If not lamp might have scatch some how?
Oct 12, 2009 | Toshiba 51H84 51" Rear Projection...
How do I dust inside the screen of a Rear projection TV?
Unplug tv first Usually you can pop the front screen off the set. There may be two hidden catches depending on the model. You may want to use two people for this. Once the screen is off removed the spider web and clean the back mirror with some windex, don't clean the inside of screen with any cleaner. Replace carefully the screen making sure it clicks back correctly
Mar 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Hitachi 51UWX20B spider web like lines help
I know my response is a while after you asked, but to clean the inside of the tv case is pretty simple.
Remove the bottom speaker cover...on this model you just pull it off. There is no clips or screws.
Once the speaker cover is off you will see the bottom of the screen, there is 4-5 screws on the bottom on each side....I think 4 in the gray plastic and 1 in a black metal strap. With all of those screws out pull out SLIGHTLY on the screen and push up. The top is held in with a down force clamp and you are just popping it out of that....It will pop back in once you are done.
Now clean the back side of the screen, the mirror and CAREFULLY dust off the lenses. I myself did not want to use any cleaners (to avoid streaking) so I used a new microfiber dusting cloth. My picture became brighter and the "crack" that I thought I had was just a dust web....
Hope this helps and good luck
N8
Mar 06, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Broken Screen
screens cost about 1000 and up - usually not worth replacing
Feb 25, 2009 | Philips 52 In. LCD HDTV
Possible spider web inside of reprojection Tv
Yyou can clean screen's internal side by takeing off back cover of tv. Belo is picture how to open back cover.
Sep 24, 2008 | Sony KP-46WT500 46" Rear Projection...
51 inch magnavox - scratch in screen
I dont know if they sell them but Philips has parts distrubitor
phone # 1-800-432-8542
also try 1-800-638-3328
good luck, I dont expcet any of that is cheap...
Aug 30, 2008 | Philips Magnavox 51MP392H Rear Projection...
Dirty screen but it is behind the outside screen.
The front screen with the frame does remove from the cabinet giving you access to the mirror and CRT lens. Remove the speaker grill,remove the four screws on the bottom of the frame, then working underneath a corner proceed to pop the rivets holding the frame to the cabinet. It will seem impossible at first because you have to use a lot of force to pop each one out.When reinstalling,a rubber mallet may help popping each rivet back in (I am not kidding when I say they are tight)
Oct 24, 2007 | Hitachi 50UX57B 50" Rear Projection...
Trying To Remove Screen
I have a panasonic 53 inch and have had the same problem on numerous occasions. I removed the backing of the television, stuck my vaccuum cleaner hose inside the tv and sucked out the spider and the web.
Apr 29, 2007 | Toshiba 65H81 65" Rear Projection...
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
62 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
