I have an Advent T9208. It has always worked well but today when my daughter started it up it made some grinding noises and will not boot up. It sounds serious. Is there a way to get it to boot up? I have a recovery disk but although it is runnning nothing seems to be happening. The system is Windows XP.
  • 397 Answers
SOURCE: I tried to image copy
Where was the destination for your ghost image? was it to another partition or folder on your harddrive, a seperate harddrive or DVD disks?
Posted on Aug 14, 2008
sandrew
  • 2961 Answers
SOURCE: Only getting EMachines/Windows XP Logo when boot up T3882
you have not set the cdrom as first boot device in the bios (press F2 or Del on boot up to get in bios), choose cd as first boot device, save settings and restart the pc with your cd in the drive and then when prompted press enter
Posted on Aug 18, 2008
  • 11 Answers
SOURCE: Ntldr compressed
Need more info
Posted on Aug 25, 2008
Bat1956
  • 585 Answers
SOURCE: I need a system recovery disk for my Gateway Desktop
If the computer originally came with a backup software disk, you can try contacting gateway for a replacement. If the backup software was instead on a dedicated partition of the original drive you will need an XP home system disk, in which case you can probably get a better deal off the shelf at a retailer. Be sure you get the full version and not an upgrade, as you don't have any windows system currently installed for an upgrade to detect. If your Gateway has a Windows XP COA affixed and you can borrow a full XP Home installation disk from a friend you can install from that disk inputting your number from your COA when prompted. (don't use your friends COA) Microsoft will recognize this as a genuine restored installation so long as you have not changed any other major hardware in the system, and you input the same information for activation as you did originally. And you can get the service packs and other updates just as you always have.
Or: you could become a Linux user for free. For the Linux newbie I would have to recommend the Ubuntu or PCLinuxOS for their user-friendliness. Again that's FREE! if you try it and don't like it you're out exactly $0.00! My systems have been Linux exclusively for about 7 years, and am kinda partial to the Mandriva distributions, though I tried PCLinuxOS a while back and have had that on this system ever since, though it has it's quirks. But don't all systems?
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Dec 30, 2008
  • 433 Answers
SOURCE: The system won't recognize the hard drive to boot up. Is there a boot disk so I don't have to do a system recovery?
I think the hard drive has failed. Sorry
Posted on May 11, 2009
Brakes make a whistle noise when applied and sometimes a low grown or grinding when coming to a slow stop or start.
A grinding or rumbling noise can also be symptoms of a wheel bearing or constant velocity joint in a driveshaft. A worn wheel bearing can also cause a 'whistling' sound (as can a worn CV joint).
A grinding noise with brakes is either worn pads causing metal to metal contact on the brake disk/rotor, or the brake backing plate catching on a spinning rotor ... or a loose/missing anti squeal brake shim (they stop the pads from rattling and vibrating).
However, as you say a mechanic has looked at the brakes and can't find anything wrong .. I think I would begin to suspect a wheel bearing or constant velocity joint on the driveshaft (front wheel drive cars).
May 05, 2016 | 2007 Honda Accord Sedan
Power wheels cadillac escalade is making grinding noise and not moving
You need to relist this problem. This is for real Cars and Trucks. It sounds like the drive gear is ground off or you have sand of something jamming the gears.
Sep 22, 2012 | Cars & Trucks
Dvd will not play on inspiron 530
Hi Joe,
Does it happen to all CDs that you put inside the DVD player?
Do you hear any grinding noise ? If you always hear a grinding noise then its already a mechanical issue on your dvd drive.
You can also try booting up to a bootable disc (like your OS disc), if its not able to boot up to your OS disc, then you already need to replace your DVD or Optical drive.
Hope you find this helpful.
Thanks,
Dennis
Oct 25, 2011 | Dell Inspiron 530s Desktop Computer
Windows wont start
Try to get into the setup, if you can't see anything in the screen when powering on, it's probably a motherboard/electronic/hardware problem. Suggestion -> Replace the machine and buy brand (DELL, SONY, ACER, TOSHIBA, IBM, LENOVO).
If you can get to the setup, go to the boot section and put the DVD Drive in first place, save and quit, put your windows recovery CD in the drive and recover.
If you can't recover, format the machine and do a clean install.
If you can't format, probably you have a bad hard drive, replace and reinstall OS.
Oct 27, 2009 | Computers & Internet
Advent 4211c will not turn on atall it says windows boot manager...windows failed to start and i do not have a windows installatin disk. how can i sort this problem out if atall .this is the only thing...
This is a boot config problem.
The fix will require that you have the Windows XP cd. Maybe you can borrow one from a friend in order to fix this. Once you have the cd, navigate to the following link for step by step instructons.
http://www.webtree.ca/windowsxp/repair_xp.htm#How%20to%20Repair%20the%20Boot%20Sector:
Sep 24, 2009 | Advent 4211c Notebook
I accelerate my 2000 neon, and it vibrates and get grinding noise
Check the front drive axles and boots. A bad cv (constant velocity) joint can cause this.
May 09, 2009 | 2004 Dodge Ram 1500
Noise
IF THE NOISE IS IN THE FRONT AND ONLY WHEN WHEELS ARE TURNING AND THE GRINDING NOISE CHANGES WHEN TURNING LFT. OR RGHT. COULD BE FRONT WHEEL BEARING..OR CV JOINT..
Mar 12, 2009 | 1996 Volkswagen Golf
Machine makes a loud noise and will not make stitches.
sounds like something is broken. best to get it checked out. take to the sewing machine doctor.
Oct 16, 2008 | Brother CS-8150 Computerized Sewing...
Power light on but nobody's home?
The power supplies in most all the smaller combo units are prone to failure. They feed both the TV and the VCR and are underdesigned as they try to keep the cost of a combo affordable.
I've never had much success solving them - sorry
They always break that last time!
Jan 08, 2008 | Recoton Advent Advent DV1418A 14 in....
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
