Question about Belkin (F5D9230-4) Wireless Router (F5D92304)
Belkin wireless problem
Hi I have a virgin media broadband supply, and they sent a modem and router. I bought a belkin USB wireless device to pick up the wireless on my laptop. All the other laptops in our house connect directly to the network and it works fine, as does my laptop if I use a cable from the modem. But the wireless USB device says its connected to the network and that the strength is excellent, however when I load any internet page it says 'cannot find server'. When I tried to 'repair' the problem, it told me that it could not 'renew my IP address'. Please help!
    Novelist:
  • 173 Answers
If you are connected straight from the modem, your router will not have internet access, only if your modem is connected to the router you will be able to go online wireless. connect your modem to the router nad router to the desktop, so that you can access both wired and wireless connection
Posted on Aug 15, 2008
Trouble replacing a USB modem with a Dlink 615 on Virgin Media
First: Turn off your USB modem.
Second: Setup your D-Link for connection
Feb 25, 2010 | D-Link DIR-615 Wireless Router
11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
My laptop has vista installed via usb from virgin cable modem.what must i do to install a belkin wireless g mimo router using ethernet connection?
Huh? You installed Vista through your Virgin Cable Modem? What on earth does that mean?
Are you trying to ask "How do I install my Belkin Wireless G Router?"
If that is the actual question, here is the answer:
1) Unplug your cable modem from your computer.
2) Plug the cable modem into the router using a Ethernet Cable.
3) Plug the router into the computer using another Ethernet Cable.
4) Plug in the power supply for the cable modem and then the router.
(If your cable modem is ONLY USB, and doesn't have a spot to plug in a Ethernet Cable, you'll have to call Virgin and replace the modem with a model that does)
Once everything is up and running, you should be on the internet as soon as the computer starts.
(You may want to log into the router and disable the "Wireless" settings if you aren't using them to stop others from gaining entry to your network)
Oct 23, 2008 | Belkin Computers & Internet
I have purchased a belkinf5d8233uk4 and have trouble connecting to virgin broadband as cable from virgin into modem is screw in can you help
you still have to use the modem from virgin, mine is setup the same but with a different router, you have the virgin rounter connected to the wireless router then the belkin wireless rounter connectes to you pc instead of the virgin router, your gonna have to log onto the router and setup some security to make the connection safe from others using it.
Sep 08, 2008 | Belkin Computers & Internet
I am a very untechnical person and I bought a wireless G Router thinking I could connect it very simply and make my wired broadband wireless. Unfortunately the modem I have, which was sent to me by Virgin...
I'm thinking you have the ADSL modem supplied by Virgin with only the telephone line port and an USB port on the back that goes to the computer.
In the case above. You need to buy a wireless router with a USB port connection. Or something like a Linksys WAG54G which is an ADSL and wireless router all-in-one.
Aug 16, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have bought a belkin wireless g router. my pc is virgin broadband i need to connect an aspire lap top. where do i plug in to make the router work
If you have your pc connected directly to your Virgin Broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Then connect the same cable to your Belkin Routers Internet/WAN port. Then take the extra cable that came with the Belkin router and connect it to 1 of the 4 lan ports on the Belkin router. Then connect the other end to your PC in the LAN port.
After that, restart your PC and everything should be fine.
Thanks
Jul 23, 2008 | Belkin Computers & Internet
I purchased a Belkin N1 Wireless USB adapter recommended to me by PC World but it is not working correctly. It WILL locate my network but will NOT allow internet access on it. I did ask specifically in the...
Hi there!
Theoretically, it should work with each other. I didn't find any documentation at Belkin's site that states the N1 USB adapter being not compatible with 3rd party devices like your Netgear router.
From what I know is N-Draft's wireless technology should be backwards compatible with both wireless-B and wireless-G devices.
1. Do you have other working wireless devices at your network during that time that you have the N1 USB adapter?
2. Were you able to connect to your wireless network? If Yes, what was your IP address at the wireless computer incase you had the chance to check it?
Maybe you can try to inquire with Belkin about what you've encountered with their device for clarification.
Hope this helps!
May 04, 2008 | Computers & Internet
Belkin (F5D7633-4) Wireless Router and SpeedTouch 360
I have solved this issues. I simply had to change the VPI/VCI values which i have obtained from my ISP. These value differ from one ISP to another.
Thanks for all the people tried to help me!
Mar 02, 2008 | Belkin (F5D7633UK4A) Wireless Router
ISP
I have a feeling I might be able to find the router setup information if you can tell me the correct answer to the prompts needing answered by this link
Virgin Media Broadband Help
The model number of the Belkin router may be of interest if detailed configuration instructions are required and because there is the a report of an issue with a specific belkin router model on the Virgin Media site that appears to require a firmware update to work well with that particular internet service.
Dec 13, 2007 | Belkin (F5D9230-4) Wireless Router...
Belkin (F5D9230-4) Wireless Router (F5D92304) Logo
196 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
