Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Laptop was dropped, i think there may be loose connection as when you press the power button there is a faint ticking noise but i am Unable to remove the base to get to the power supply, seems to be a connector of some sorts just under the letter U which is keeping it tightly in position. Any Ideas?
  • 3,051 Answers
If you go to yahoo and type in laptop diagrams it will bring you to a page that will explain step by step on dissambley of any laptop ok hope this is helpful and please dont forget to rate this for me ok best regards miket
Posted on Aug 24, 2008
What is ticking noise from passenger side of motor?
Michael, check your engines oil level right away, low or dirty oil is the main cause. Other things that can cause this issue could be worn or dirty cam lifters or tappets, exhaust leak, loose worn timing chain, possible EGR valve cracked or leaking at base, bad belt or tension er, the list could go on. PRESS THE HELPFUL BUTTON and check links below
What That Ticking From Your Engine
Engine Ticking Clunking Noise Repair
Tick Tick Tick Troubleshooting By Ear
3 4l gm infamous engine ticking noise
Feb 09, 2016 | Cars & Trucks
Wii has solid red light, won't turn on, faint ticking noise
if it was dropped check the bluetooth module , they can come unplugged and the wii will not function. Children love to put change in the wii which can short it out. Never bridge a fuse as it can cause unsafe conditions and potentially a fire hazard .
May 08, 2014 | Nintendo Wii Video Game Consoles & Games
Press start button laptop just buzzes
Has it been dropped, or is there any kind of holes that something could have lodged into it? Otherwise it sounds like the battery needs to be replaced, as it is not getting enough power.
Your local Electronics store may be able to check your battery out for you, but I would suggest calling first to make sure there is no charge for the visit.
Why are you holding down the power button? That can ruin the button.
Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Jan 27, 2014 | Packard Bell Computers & Internet
Acer Travelmate 6592G Charging problem
The power adapter id under powered by 1.32A that is why it takes a long time to charge and it is putting a lot of stress on the adapter and could cause it to overheat. The ticking sound could be the thermal cut out cutting the power to the laptop to prevent the power adapter from failing.
Mar 17, 2013 | Acer TravelMate 6592G-602G25Mn Notebook
My external is making a faint tick, tick, tick
I am sorry to inform you that your drive is failing. Normally drives will start with a faint ticking then move onto a solid clicking sound and maybe even a grinding noise. You will need to backup all of the data on that drive and then download the diagnostic utilities from your drive's manufacture and run the testing tool. If you can hear any ticking there is a very good chance the drive will fail the diagnostic tests. Assuming it fails you will then be able to RMA your drive for a working one as long as it is still under the warranty period. If your drive passes all the testing from the manufacture's tool I would advise you backup your data from that drive regularly and run the diagnostics weekly until it throws and error code.
Jul 23, 2009 | Computers & Internet
Kenmore 70 series model 97576200
You have a bad thermal fuse , usually caused by lint blockage from the filter or vent hose .
Jul 06, 2009 | Kenmore 659 Electric Dryer
Dell monitor blank. nothing appears on screen. light is blinking by minitor power button, but nothing at all on screen. I hooked up to my laptop, still nothing. Checked power/ tried new power cable. No...
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
Apr 08, 2009 | Dell E773C 17" CRT Monitor
Powering on
OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
Hope this works for some others.
May 23, 2008 | LeapFrog FLY Fusion Pentop Computer
No Picture No Sound
I think you have a short somewhere inyour set most likely the horizontal output transistor which may have shorted by the high voltage transformer going bad. The faint ticking sound that you hear is the power supply trying to start but the shorted load won't let it. Stargazer
Apr 22, 2007 | Samsung TSL3099WHF 30" TV
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
251 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
