Question about HP LaserJet 4L Printer
Hp photosmartc4180 all-in one
I had the black ink carthrige refill. And my printer keep advising that there is a probleme with the black ink carthrige ??? what is the probleme
After I did the calibrate it stopped giving me this message. I turned off everything and as they say: shut down and turn on again.
Posted on Aug 12, 2008
SOURCE:
Hello,after refilling ink cartridges HP21 and
Since HP’s ink technology is different from other manufacturers, they do not recommend to use refilled or remanufactured ink cartridges. Though the cost of genuine HP cartridges are bit expensive than the other cartridges, HP cartridges are manufactured in keeping mind the important factors print quality and customer satisfaction. Using the refilled cartridges may degrade the print quality and may damage the printer’s internal hardware.
I request you to use genuine HP Inkjet cartridges and verify the result.
:) Dr Tony
May 10, 2010 | Office Equipment & Supplies
Hp black cartiedge is low on immediately
When you refill a cartridge, the printer will keep warning you that it is empty- a message pops out that says "low ink". That is because the printer sees the cartridge by it's serial number. The printer can't know that you have refilled the cartridge, so it keeps saying that it is empty. Once you put in a new cartridge, it will display the cartridge as full again.
May 02, 2010 | HP Easy Refill Kit for (HP) Black Inkjet...
Problems with the black ink cartridge. Freshly refilled with black ink and the prints are coming out light grey and inconsistent. The machine itself keeps reporting a problem with the black cartridge.
When you refill a cartridge you must be syre that there are not any air bubbles left in the cartridge because that can overheat your cartridge printhead
take a look how you can have a success refilling
http://www.youtube.com/watch?v=C6-N-Pxmjxk
Apr 30, 2010 | HP OfficeJet J4580 All-In-One Laser...
HP officejet 7210 error message color ink refill
this error is recomded for the printer becouse printer will count the print out
Apr 12, 2010 | HP Officejet 7210 All-In-One InkJet...
Is it possible to use non HP ink in ths printer? Tried using "remanufactured ink", and concluded that this printer may be programed to block the use of NON HP INK.
It is always recommended to use genuine HP cartridges.
As if we will use the non HP or refilled cartridges, it will reduce the life of the printer.
And we will get an error "cartridge problem".
Plaese use the below cartridges, which are compatible with this printer.
HP 02 Black 660 pages
HP 02 Black Twin Pack 1320 pages
HP 02 Color Combo See single 02 inks
HP 02 Cyan 400 pages
HP 02 Light Cyan 240 photos
HP 02 Light Magenta 240 photos
HP 02 Magenta 370 pages
HP 02 Photo Value Pack 150 photos
HP 02 Yellow 500 pages
HP 02XL Cyan 600 pages
HP 02XL Magenta 555 pages
HP 02XL Yellow 750 pages
Apr 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
I put a refilled black ink in my HP PSXçC
the problem with the refilled ink is that the ink is NO WHERE near as good as the original HP ink and the ink cartridge is now damaged - just replace the cartridge with a new HP cartridge and you should be OK!
Dec 09, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp94c Installed refilled black ink but printer does not recognize
try cleaning the contacts with a wet towel
from both cartridge (black and color) and in the printer
where the cartridges get in (metal pins)
Jun 07, 2009 | HP DeskJet 940c InkJet Printer
Changing ink carthrige
hi try to clean the contact point of ink and ink carrier.if it's not work 2 thing you need to consider....
1.maybe your ink is not compatible or not detected..
2.maybe your ink carrier is most likely defective.
hope this would help you...
Oct 27, 2008 | HP DeskJet 820cxi InkJet Printer
Installing print cartridges
refilling catridges is not advisable it is better always go for new one .bcoz the ink which is used for refilling it is not good which is damaged the print head and the the catridge nozzle . i will advise you to buy a new actridge and install . bye
Sep 21, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP LaserJet 4L Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
