Question about Kitchen Ranges
I have a Kelvinator S2840 and have no idea how the timer/clock works. We bought it with the house and there is no instruction manual.
2 Suggested Answers
SOURCE:
SOURCE: Instruction manual for a Belling Platinum Dual Fuel DB2
main oven not working
Posted on Dec 02, 2012
Using Lowes mechanical timer in Hadco TC654-15 landscape lighting transformer. Have tried 3 timers now and timer clock does not work when plugged into the transformer. if I bypass the timer, low voltage...
Always a good idea to check outlet with cheap circuit analyzer.
And move timer to different outlet to see if difficulties are outlet-specific.
Try timer at neighbor's house.
Having 3 defects in a row is unusual.
There are no repairs for defective timers.
Timer clock motors stop working for many reasons, bad manufacturing of plastic gears and power surge and dirt and reversed polarity among the causes.
Using household plug-in timer is typical solution since clock modules are not sold separately.
Following link gives tips for having low-voltage power pack last longer, in case you decide to buy Intermatic-Malibu from Home Depot:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Aug 31, 2011 | Hadco TC151-12TP Accessory Transformer
My Intermatic timer is not working. I replaced the WG1573-10D motor but still it does not work. The manual override works so the power supply is ok. Any suggestions welcome.
Your question doesn't provide enough information.
You have 240Volt T104 Intermatic timer?
A) WG1573 is for 240 volt timer. If you have T101 or T103 timer, it takes 125V clock motor.
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
B) This is new installation? and clock motor only worked when override was ON, so you bought new clock motor. But actual problem is that wires from Load and Breaker are reversed.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
C) Your timer worked fine in past years, but dial stopped rotating so you bought new clock motor?
You replaced clock motor.
Manual override works.
--And then your information ends.
Does clock motor work? Does the dial turn? Are your on-off trippers on the dial?
Are tripper worn down?
Buy new trippers.
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
If clock motor does not work, and circuit is 240Volts, then I suspect you connected clock motor to wrong terminals>? Clock motor connects to terminals 1 and 3.
Add a comment and fill in details so we can properly troubleshoot.
Dec 04, 2010 | RTO Intermatic Inc Wg1573-10d Replacement...
I bought a new house and the water heater has a circulating pump with a Taco 265 timer. No instruction manual so I can't figure out how to set the timer. You wouldn't happen to have a little instruction...
Maim website:
http://www.taco-hvac.com
Main website Search for Taco 265-1 gives link to manuals:
http://www.taco-hvac.com/search.html?gsearch=Taco-265-1&action=results&cb_products=YES&cb_filelibrary=YES&cb_news=YES&search_type=all_terms
Direct link to pdf manual:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.taco-hvac.com/uploads/FileLibrary/102-067.pdf
Instructions show series of actions to set digital program
Press h key ...
Press m key...
Press Day key...
Press Prog. key to enter...
Sep 10, 2010 | Taco 265-1 / 563-2 Combination Analog 24...
Need a manual for drayton tempus 3 heating control
I've ended up with a Drayton Tempus 3 when I bought my house, and I think this is how it works. It allows you to set 2 Timers (I'll call them timer 1 and timer 2) so that you can control Hot Water or Heating On/Off times twice a day. The unit has 6 buttons - 2 for Adjustment, 2 for Hot Water and 2 for Heating. The 2 Adjustment buttons allow you adjust the Clock Time, or allow you to adjust Timer 1 and/or Timer 2. NOTE: Timer 1 is the time refered to on the Heating / Hot Water Select buttons if you press "Once". If you select "Twice" on these the both Timer 1 and Timer 2 are taken into account. For example if you want Hot Water to come on Once between 8pm -10pm, but you want Heating to come on Twice between 6am - 7am, and 8pm -10pm, you have to do the following: Set Timer 1 to 8pm - 10pm, and set Timer 2 to 6am -7pm. Then select Once for Hot Water, and select Twice for Heating. Hope this helps.
Mar 23, 2009 | Water Heaters
Manual needed for Range operation: Specifically timer reset
I found the work-around to be to decrement the timer to 0 as a means of canceling it, "unset it" if you will.
Dec 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Programming Belling xou181ss oven
Try Googling (belling)(xou181ss)(manual) without parens.
May 01, 2017 | Ovens
Kitchen Ranges Logo
64 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
