Question about Garmin GPS
Garmin StreetPilot c340 stop responding no sound, no movement at all - DEAD! Serial #116484764 Registration Code VADUCBQ
  • csullivan48 Aug 12, 2008
    This not working. Not RESPONDING - Period!
    Master:
  • 521 Answers
Open the front casing and hit the reset button under the cover, then it will turn on while you plug it into the car adapter.and it will work
Posted on Aug 12, 2008
  • Garmin Master
  • 6,487 Answers
Try first resetting the unit , follow this steps:
Unplug the power and the usb cable from it.
Place your thumbnail inj the groove located under the garmin logo on the faceplate and gently pull off the faceplate.
Press the Reset button for 3 seconds
Then connect the unit to the power source and check if it will respond now..
Hope that helps........
    Genius:
  • 2,035 Answers
Please unplug the device from the power supply for 30 min ,switched off ,remove the battery and then switch it on and check if its working .....
Good luck..
    Guru:
  • 1,894 Answers
Please leave the unit with out power for few hours and then again start the unit.
that may help you in some cases
I ran the battery dead on my c340 GPS Now
You will have to open up you unit, and replacing the battery, you can get them from Garmin.
May 08, 2010 | Garmin StreetPilot c340 GPS Receiver
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
Update 2009 maps into c340 how to
Try Here for the updates,
You may have to add Garmin to your trusted web sites !!! Firewall.
In a web browser, tools, internet optoins, security, trusted sites, sites button, add it here.
hope this helps.
Regards.
Dec 06, 2008 | Garmin StreetPilot c340 GPS Receiver
My Garmin C340 is dead!!!!
I had the same problem on a trip. Required two fixes and once I did this the unit worked fine.
1. Replace the fuse in the car adapter (reason it wasn't charging when I used it in the car).
2. See the users manual on page 31 regarding resetting your C340.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Jul 21, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Streetpilot c340 arrived dead
The battery symbol would show the charge, somethign doesn't pop up.
May 08, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot 33o
Did you try to upgrade your Garmin with 2008 maps? If you have the map registration code then you will have to go to garmin's website and get an unlock code. You will need the registration code and also the unit serial number before you can get a new unlock code. The unlock code is base upon your unit serial number and will only work with that unit.
May 07, 2008 | Garmin StreetPilot C330 GPS Receiver
Lost registration code for StreetPilot c550
If you email Garmin and give them the serial number on your unit they can get your registration code
Jan 13, 2008 | Garmin StreetPilot c550 GPS Receiver
Unlock - rgistration code
If you email Garmin with the serial number of the unit they can send you your registration code.
Jan 13, 2008 | Garmin StreetPilot c340 GPS Receiver
Registration code
You will have to buy a regular copy of Mapsource NT (do not buy the update version). The regular copy will come with a serial number and then you will have to register with www.garmin.com to get the unlock code. Also you will need the unit serial number on your i3, (it can be found by removing the battery cover).
Dec 28, 2007 | Garmin StreetPilot i3 GPS Receiver
Garmin c340 gps
It still should be under the one year warranty with Garmin. Call Garmin support and get a RMA.
Nov 25, 2007 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
65 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
