Question about Nikon Cameras
I dropped my D40 and two of the three flanges that hold the lens in place broke. The lens still functions but needs to be held tightly to the body. Can I have this repaired? And how would this happen?
    Genius:
  • 2,985 Answers
I dounbt very much if this will be repaired - contqatcthe customer support for you camera
Posted on Aug 12, 2008
My nikon lens af-s DX NIKKOR is stuck won't turn
The lens and housing will probably need to be replaced, but I would take it to a camera repair shop and have it checked to rule out other problems before proceeding with repairs.
Jul 03, 2012 | Nikon D40 Digital Camera with G-II 18-55mm...
Remove bathroom sink flange
Turn off the water valves at the back of the sink and place a bucket underneath the drain to catch any water that may run out.
2 Loosen the nuts that hold together the drain tailpiece and the P-trap with a wrench. Disconnect the the two pieces.
3 Unscrew the drain tailpiece from the drain flange. Depending on how the drain flange is held in place, you may need to hold it down firmly as you twist the tailpiece below. Remove the tailpiece and set it aside.
4 Remove the old drain flange. It may come straight out after the tailpiece is removed, or it may be held in place with putty or silicone. If it is held in place tightly, grasp the edge with a pair of pliers and pull until it comes free.
5 Wipe down the sink area that was underneath the old flange. If the metal was discoloring or rusting, clean the porcelain well and dry it to keep the new flange clean.
6 Apply a thin bead of silicone caulk to the underside of the new flange. Push the new flange into the drain hole in the sink.
7 Push the drain tailpiece back up into the sink's drain from below and screw it into the flange tightly. Use a wrench to tighten it up securely.
8 Reconnect the P-trap to the tailpiece and tighten the nuts that hold it in place. Turn on the water supply to the sink and run water through the pipes to ensure everything is securely fastened.
Things You Will Need
  • Bucket
  • Pliers
  • Adjustable wrench
  • Silicone caulk
Duplex Steel flanges Duplex Stainless Steel Flanges Manufacturers Suppliers Instinox
Feb 12, 2012 | Kohler Plumbing
I broke a part in the engine that i thought was the thermostat but it is not and no one can tell me what the name of the part is can you help
How did you think someone would be able to tell you what it is without any description or without being able to see it?
Jan 28, 2011 | 1988 Toyota Pickup
Dropped my camera Nikon d40
It sounds as if you have broke the lens. Repair or replace.
Dec 14, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 (very dark photographs)
If lens has aperture ring make sure its set to highest aperture (f22 etc). With nikon CPU lenses, all exposure metering is done inside lens, sounds like lens still has problems. Try another lens to test camera body, camera shop should be willing to help with this.
Apr 11, 2008 | Nikon D40x Digital Camera
Auto focusing problem
The D40 will only autofocus with the Nikkor AF-S lens...look for the AF-S in the lens title. For 3rd party lens, only SIGMA with the USM title will autofocus.
To use the T-adaptor...you will need to use the "Manual" mode of the camera.
Dec 28, 2007 | Cameras
Canon lens 18-55mm for canon rebel xt
New lens is on the Horizon here I guess any repairs will be costly
Aug 17, 2007 | Canon Digital Rebel / EOS-300D Digital...
Cameras Logo
18 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
