Question about Copystar CS-1810 Copier
I got the code c610 on my copystar cs-1810, how to fix, and where i can get the manual as well
  • 200 Answers
Broken fixing heater wire
? It takes 15 s or more for the fixing temperature to reach 50°C/122°F after the power is turned on or the safety switch is turned off and on.
Fixing unit thermistor installed incorrectly.
Check and reinstall if necessary.
? It takes 10 s or more for the fixing temperature to reach 100°C/212°F from 50°C/122°F.
? It takes 24 s or more for the fixing temperature to reach the secondary stabilization fixing temperature from the primary stabilization fixing temperature.
Fixing unit thermostat triggered.
Check for continuity. If none, replace the fixing unit thermostat.
Posted on May 18, 2011
SOURCE:
Copystar CS1810 shows error code J00. How do I fix this?
J00 means that the machine did not pick. remove the cassette and the put back and press start again
Feb 15, 2011 | Copystar CS-1810 Copier
Instruction how to operate CS-1810 copystar printer
Go to Kyocera in your country.Most manuals are available on line free.
Jun 12, 2010 | Copystar CS-1810 Copier
Copystar CS-1810 copier- what does A 400 mean?
that means your laser unit is not spinning up to speed. sometimes, you can fix by pulling laser unit and removing the polygon lens/mirror, then putting a small drop of lube on shaft and re-assembling. other times, you have to replace laser unit. thats quite expensive.
hth,
razors
Mar 16, 2010 | Copystar CS-1810 Copier
Copystar 1810 document feeder slips grinding noice
Sorry Mike,
No spare parts are available.
Jun 27, 2009 | Copystar CS-1810 Copier
Code e70 on copystar 1810
Jam code 70 means: No origional feed. Paper is detected on the doc feedr tray, but when the start button is pushed - the origional don't feed through.
Mar 12, 2009 | Copystar CS-1810 Copier
COPYSTAR CS-1810
Hello sir; "AP" isn't a problem, just let it run for a little while, it will disappear.
Feb 18, 2009 | Copystar CS-1810 Copier
Copystar CS-1810
You need to run sim U163 to reset fixing heater problems. Press and hold stop, start, and left exposure key in that order. Release and press stop again. Use zoom keys to enter 163, press start. Exit the mode by entering 001 and start, or power off/on.
Jul 21, 2008 | Copystar CS-1810 Copier
Copystar CS-1810 Error Code
I'm sorry, Copystar is not a brand I am familiar with.
Be blessed.
Mar 19, 2008 | Copystar CS-1810 Copier
Copystar CS-1810 instruction book
manual download link
http://usa.copystar.com/CopyStarPub/jsp/Kyocera/resource_details.jsp?rid=2076
If it only has lines on copys then
Clean scanner glass (small slit of glass before copy glass)
If it happens on prints and copys then it will more likely be drum.
Nov 10, 2007 | Copystar CS-1810 Copier
Copystar CS-1810 Copier Logo
216 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
polytek
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
