Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirpool washer my washer seems to be leaving what looks like transparent grease stains on my clothes
  • 639 Answers
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
We have a Frigidaire Gallery 16 cycle Front loading clothes washer purchased in 2002 and it is leaving what looks like grease streaks and stains on some clothes. We have washed only with Cold water. any...
I removed the drawer for detergent and bleach dispensing and it was
quite dirty form build up of dirt and detergent.
than ran hot water cycles and it seemed to fix.
Oct 14, 2009 | Frigidaire Washing Machines
Gas dryer leaves black grease spots on clothes
the soot is coming from the flame at the gas heater box the drier needs to be converted to propane the flame is too large without the conversion kit installed and thus creates soot at the vent. contact a local repair place for this one it can be tricky.
Sep 12, 2009 | Whirlpool LGR5636L Gas Dryer
My washer is leaving discolored stains on my clothes. it shows up most prominently on whites, they almost look like shadow stains, but they're getting worse. what is causing this?
If this is a top load machine, you have a bad tub bearing. This will cause your clothes to have what looks like rust stains on them. It's actually grease form the bearing. It can be replaced and I would rate it a 6 on a scale of 1 to 10, 10 being the hardest.
Please rate solution
Sep 02, 2009 | Washing Machines
My Frigidaire Washer Leaves Stains all over our clothes
Since this happened from day 1, your water may be the problem. Do you have well water? If so, get a softener system. This will get rid of the iron, which is responsible for rust stains. I really doubt that a new machine would cause rust or grease.
Why didn't you do something five years ago when you first noticed this? It will be much more difficult to get a resolution from the manufacturer after5 years.
Jul 31, 2009 | Frigidaire GLTF2940ES Front Load Washer
Grease-like stains on clothing
hi. i can help. the grease is coming from one of two places. Either some item with grease on it got placed in the machine and the grease transferred to the tub where it will cause the problem until it is spotted and removed with a degreaser, or wears off.
OR the grease is coming from the washer itself. Perhaps some grease oozed out of the mechanicals related to the aggitator.
Either way I would get a strong flash light or trouble light and look carefully in the tub and around the aggitator for grease. Then remove it with a cloth and some degreaser, available at any auto parts store.
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Clothing stains
Get a flash light and look very closely at the entire inside of the washer. what you are looking for is a little yellow grease, which is causing this problem. if you find the grease, remove it with a degreaser and you will be fine.
Jun 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Model RTW4340SQ0 clothes waster leaves oil-type stains on clothes
Remove agitator cap. Remove bolt underneath. lift off upper agitator and lower. Look for grease under agitator and on splined shaft and clean. Re-assemble be sure to put plastic thrust piece in between upper and lower agitator.
Jun 13, 2009 | Roper RAX4233PQ Top Load Washer
Washer is leaving grease all over my clothes
I have this problem on my front loading washer too, but only when washing white clothes. I have just read that perhaps the inlet hose is disintegrating from the hot water being too hot. The hose disintergration can cause black greasy stains on the clothes. I am going to check out the inlet hose when I get home. Hopefully this is the problem... I am sure a new inlet hose is a lot cheaper than a new transmission or new bearings. BTW, my washer in only 18 months old.
May 18, 2009 | Washing Machines
WHIRLPOOL ULTIMATE CARE II MAKES YELLOW BROWN STAINS ON LIGHT COLOR CLOTHES
Grease will not come from the interior of the washer, as the machine ages build up deposits under the basket and it is oily, greasy and full of mildew. If can get a spanner wrench from a appliance parts house and remove the basket you will see on machines older than three years a build up starting. I pulled 15 lbs from a 25 year old machine and I had to go get sick outside, it was bad.
Sep 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
136 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
