Question about Hamilton Beach BrewStation 47214 Coffee Maker
Won't brew a full pot.
My Brew Station won't brew a full pot of coffee. The water will not run through a complete cycle. I have to turn my pot off and on 3 or 4 times before all of the water will go through. When this first started my light would blink as if I had put it on the timer. Now the light stays on but doesn't complete the cycle. I love my Brew Station and would love to find a way to fix this.
  • 2 more comments
  • doggybizkit Sep 21, 2008
    My BrewStation is doing the same and it's driving me nuts..I just bought the coffe pot a few months ago.
  • Anonymous Sep 28, 2008
    I have the same problem. The coffee maker will brew only a few cups of coffee, and then I need to turn it off and back on again to make it brew more coffee. The problem seem to be getting worse. I haved cleaned the coffee maker well and this has not solved the problem.
  • Anonymous Mar 14, 2014
    only brews about two thirds of water. I used to get almost all of water brewed.
  • Anonymous Mar 23, 2014
    Have to push start button multiply times per carafe
Well I hope this helps some, i was having a similar problem with my brewstation and decided to take it apart ( why not, it's already broken! ) this machine has seen a year of very heavy use and I could not bring myself to just throw it away. It would take forever to brew and I would have to turn it off and on several times to brew a full pot. I unplugged the machine, emptied out the water and turned it on it's back. Remove the 4 phillipshead screws and the two torx screws from the bottom ( if you dont have torx handy like me just gently pry the two halves apart till the screws pull through- after you have removed the phillips heads!) at this point the bottom will just come right off, no special tricks. You will now see a horseshoe shaped aluminum tube with orange silicone tubes at either ends of it, this is the heatime element. slide the small hose clamps back away from the element on the hoses and pull the hoses off both sides of the element end only, this will require a little elbow grease to do. Now carefully remove the two phillips screws securing the heating element to the maker BE OBSERVANT AS TO HOW THE WASHERS AND SPACERS ARE SECURED and remove them. To give yourself a little room for the element to come further out of the machine also remove the wiring clamp from the inside, it is a white half "c" plastic piece with 2 screws holding it, it is securing about 7 wires down with wire nuts on them. Once this is removed it will give you enough play to pull the heating element several inches away from the machine, do so. Now look inside the tubes of the element and you should see one side looks clear and clean and the other end is probably going to be clogged solid with tan colored gunk, the water could not pass through!. I took a piece of metal coat hangar (all i had around at the time) and bent it to the conture of the element and used it to **** out the element, uncloging it. this takes a little time because the buildup is very hard to break up. Once that is done carefully wash out the element getting all the build up that was broken up out, CLEAN IT GOOD!. The next step is to dry the exterior and make sure all the wiring is dry, try not to wet the wires at the wiring nuts or it may short out. Now re assemble the machine, run cleaner through and enjoy a cup of coffee !!
Posted on Oct 13, 2008
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
Clean instructions
First, let me clarify what the red light indicates.
A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but due to be cleaned. When the coffeemaker is due to be cleaned, the red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The entire cleaning process takes about an hour and a half. And, it is not intuitive. So, here are my instructions.
With the coffeemaker off (with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Feb 04, 2014 | Mr. Coffee JWX27 12-Cup Coffee Maker
Clean instructions
I presume you are requesting instructions for cleaning this coffeemaker...
With the coffeemaker off (either a red blinking light or no light on), pour four cups of pure white vinegar (no water added) into the reservoir. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
Sep 30, 2013 | Mr. Coffee JWX27 12-Cup Coffee Maker
Cant get the cleaning cycle to end dont know how to get it off
If the red light is still blinking, then the cleaning cycle has not yet been completed. The cleaning cycle is not intuitive. So, here are my instructions.
Jan 07, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
Model # jwx23 mr coffee cleaning instructions
I couldn't find any model JWX23. So, since your question (as much as it is) is categorized under model JWX27, I'm going to presume you need the cleaning instructions for model JWX27.
With the coffeemaker off (with no lights on or with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
Jan 01, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
We ran the clean cycle on the coffee maker and the clean cycle will not turn off.
First, let me clarify what the red light indicates. A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but is due to be cleaned.
The red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The process takes about an hour and a half and is not intuitive. So, here are my instructions.
May 15, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Apr 09, 2009 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
Won't make full pot
Okay, try this, make sure that everything is cool first, then take a turkey baster full of hot water and vinegar and shoot it backwards through the coffee maker...where the water falls on to the grinds. After that, try running either a commercial coffee pot cleaner or just again, vinegar through the brew cycle with no coffee in there. Try it two or three times, there may be calcium buildup in the filter and pump. You could also try that CLR cleaner, but make sure you rinse the pot out really good, and run a few cycles of just water before you drink anything from it.
Hope this makes sense and helps you out!
Jan 12, 2009 | GE Coffee Makers & Espresso Machines
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Hamilton Beach BrewStation 47214 Coffee Maker Logo
588 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
