Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile side by side 'fridge
Smelled a burning smell. Then fridge side quit chilling. Freezer still cold, but not cold enough. appears fan not running. Could it be fan motor burned out?
  • cc34102 Aug 29, 2008
    Think we may have gotten it! Thank you. Replaced motor and it appears to be working great! I'm beginning to regret buying a G.E.!
  • Anonymous Mar 16, 2014
    Ge freezer, burning smell
  • 74 Answers
Evaporator fan motor and main Pcb , the fan motor goes faulty and then burns out a resistor on the main pcb at the back.
Posted on Aug 28, 2008
SOURCE:
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
GE S-b-S Fridge cold but freezer warm
Take all your product out of the freezer... Take the bottom half of the back panels off and you should see a FAN that could be covered with either ICE, or burned out. If it has ICE on it, take the ICE off. If the fan is not turning then the fan could be burned out. Read the voltage tag on the back of the fan and apply a known good voltage to the fan ( after you have removed it ). That will tell you if the fan is good or bad. Start there. You got to get the air moving to chill everything...
Dec 01, 2009 | Refrigerators
Motor is running but it is not cold fride and freezer are 60deg
Sounds to me like the compressor has become faulty. it is not able to start. After a while the clixon starts to burn which explains that smell. Suggest replacement.
Sep 16, 2009 | Jenn-Air JCD2389G Side by Side...
GE Profile Artica side by side - freezer not cold enough
replace control board on back of unit there is a six by 10 inch cover on back your panel is in there cost aprox 169.00 dollers also replace bo0th thermisters bottem left of freezer looks like a white bullet the other is in fridge behind shelf trim located beside and underneath where the cold air blows into the fridge.
Aug 10, 2009 | GE Profile PSI23NCR Side by Side...
Kenmore Cold spot 106 Warm Fridge
I would replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
Jul 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Not keeping cold temperature and can smell plastic from heat
Sounds like the condenser fan motor is either jammed or has failed. if you wil pull the refrig from the wall and remove the lower compartment cover you will see the fan I'm reffering to as well as the condenser coil and compressor. if the fan has failed you can put a house fan blowing into this compartment to keep the unit operational until you can get it repaired. thanks for using FixYa Peyton
Feb 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PRofile Arctica
Just had mine with the same problem fixed today,it was the main board on the rear of the fridge,common problem with these models told by the tech.
I believe you can get a free board fom ge but you pay labour
Jun 17, 2008 | GE Profile Arctica Stainless Steel Top...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
409 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Matt Sicignano
Level 1 Expert
