When using 1 gb memory card I am only able to take 17 pictures and then the camera tells me it is full! I know I should be able to take at least 100. I have lost my hand book so am unable to solve problem please help me.
I am unable to get the format up on camera and as i have lost handbook I am stuck!I am unable to get the format up on camera and as i have lost handbook I am stuck!
You can't post conmments that contain an email address.
Re: When using 1 gb memory card I am only able to take 17...
Try formating the card from the camera, i used to have a camera that had the same problem. turned out to be a bad card. after formatting it every other day i bought a new card, hopefully yours wont be the same problem
Your device has no memory left. Camera has very limited internal memory in 'No Card Mode' which is fixed by using a removable SD Memory Card 1 GB to 32 GB.
sonia
dear
plz rduce yr resolution of picture sshootin options to minimum one
eg:349883#2347
2100#500
and
bck up data and format yr memry crd
if then
may be
call me 07891555121
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB All other V-Series Cameras: SD memory cards up to 2 GB EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
all cameras have a small internal memory, in your case three pictures, you need a memry card, your manual should tell you which type you need (although for polaroid, i think [but am not sure] thit it will be an SD card) you should probably get a 1-4 gb card, as this will let you take a few hundred photos, before you have to download them onto your computer
For all the camera users whose cameras won't format...they can't accept all the info on a 2 gb memory card... install a 1 gb card...worked like a charm for me! C315 and others were made before the 2 gb card. Only 1 gb cards work in the older cameras.
i don't know what year or model camera but 4 gb basically only work in 2 yrs or newer models-not all cameras support card due to diferent file format on sdhc cards-try going back to 1 or 2 gb and play it safe if they work
