Question about Epson Workforce 520 Printer
Im getting an error "see my documentation" on my
  • Gail Meyer
    Gail Meyer Oct 31, 2013
    This also worked for me but the cause was a power outage during printing. Thanks!
  • 21 Answers
I had this issue and contacted epson support. They had me open the top to access the cartridges and physically slide the cartridge from its resting place over to the other side and and there was a small piece of paper that got caught in a print and was between the the ink and the cleaners. I then needed to physically move the cartridges back to the resting place and then close the top. Then on the printer, go to the menu and clean the nossels and the test the cartridge. if the lines are broken at all or you dont see words at the top of the test page, then clean the nozzles again. complete this and print a test page or copy. I was good to go.
Posted on May 30, 2011
  • 7 more comments
  • Pat Hrch Sep 29, 2011
    I am receiving this same error and the solution below did not work for me. Any other thoughts?
  • Tundraflowers Jan 23, 2012
    I had been struggling with this problem for 2 days and solved it. "Printer error See Documentation" message but I had cleared all paper jams. Here's how I solved it: Turn off your printer. Open the carriage where you can see the ink cartridges. Slide the ink cartridge carrier all the way to the left manually. Just slide it all the way over with your hand. Don't close the lid yet. Turn on the printer and watch the ink cartridge carrier move. It will slowly move to the right, super slow but will go. Then it should begin to slide back and forth as normal. The error message should disappear then. It seems the printer just needed to reset itself. Hope this helps!
    Also, after moving the ink cartridges like tundraflower posted, clean the nozzles and test the cartridge. Works perfectly now.
  • danica_rolle
    danica_rolle Nov 08, 2012
    This worked OMG thank you so much. I could not be more happier, Thanks again.
  • sheilarivera
    sheilarivera Feb 01, 2013
    thank u soooo much it worked
  • hdanezekiel
    hdanezekiel Feb 04, 2013
    thank you very much! i have the same error.and what you've just said works great for me. problem solved! thanks a lot again
  • M Wade
    M Wade Feb 18, 2014
    It worked - removed the paper and it's back to normal. Thank you
  • baldechic
    baldechic Jan 12, 2017
    This helped found the piece of paper now it works like a champ Thanks for the help
  • john brunton
    john brunton Dec 29, 2017
    my pc cant find the printer could it be my usb cable
    New Friend:
Mine had same error but instead of a piece of paper stuck in it, the ink cartridge cleaner fell off the track. The cleaner being the foam pad that would be directlyunder the ink cartridge in off position. Just push the two plastic bars back up and over onto its track and that will prevent the ink cartridge from hitting it and causing an error.
Posted on Aug 08, 2013
  • Cristina Gudino
    Cristina Gudino Mar 08, 2014
    Thanks everyone! All your comments and suggestions were helpful. Russell's comment helped me though, not that the cleaner was off track, but just by moving it back and forth helped solve the error message, unfortuantely I had an additional low ink error afterwards, but that's an easy fix as well. Thanks everyone!
This worked exactly as described for me. Had a paper jam, little piece was stuck behind the print cartridge. Back up and working now. Thanks!
Posted on Nov 19, 2011
I received the same error. All I did was cleaned the ink cartridges and that fixed. I also moved the cartridges to the left to reset the cartridge drive
Posted on Sep 12, 2012
    New Friend:
After trying all of the above multiple time to no avail, I removed all the cartridges again then ANGRILY slid the magazine back and forth 10 or 15 times while calling it names, put the cartridges back in...it seemed to work fine. Called it a few more names just to make sure...no problems since.
Posted on May 21, 2016
SOURCE:
Can't open Excel files after installing OS X 10.8 Mountain Lion on my Mac. HELP PLEASE!
Try repairing disk permissions by running the Disk Utility application until you get no errors (then restarting).
Hope by doing that you get the solution.
Aug 09, 2012 | Apple OS X 10.8 Mountain Lion
PIXMA MX330 Error message "Document in
The sensor may be dirty even if it looks like there is no paper jam. Take a bottle of compressed air and give it a once over. Make sure you don't shake or tip the compressed air as you don't want to fast freeze anything.
If this does nothing, you probably have a failed sensor which will need replacing.
Chris
Aug 18, 2011 | Canon Office Equipment & Supplies
Getting "Catridge error: Refer to
if the cartridge is not sensing poperly this error may occur.clean the cartride contact and try it.
the following link may useful to you.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01571812&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=3441011
Aug 08, 2011 | HP J3680 Officejet All In One Printer
Printer error :"49.C02 service error " message
i think this caused by your windows is not genuine
Jan 14, 2011 | HP LaserJet 4700 Printer
Im getting a MySQL error saying : "Exception
Try to remove or rename your existing connection file, QB creates a new one if it does not find any existing, allowing so to recover from broken files.
MySQL Repair
Dec 27, 2010 | Sun MySQL
Hello..... im getting error when im trying to play street fighter 4 on my computer it says, "Fatal error, Failed creating the Direct3D " can you help me ? please !!!!!!
make sure there is the directx is installled and updated... (you can install it from internet..) also make sure your pc has graphics requirements for the game... make sure the directx driver is active in device manager..
Dec 22, 2010 | Capcom Street Fighter IV for Windows
Epson Workforce 520 Printer Logo
20,274 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
