Question about Toshiba Satellite A105 Notebook
Overheating issues Fan needs cleaning
Im not sure what precaution i need to take and how to disassemble and clean my laptop fan. Can you please help me. Please and Thank you.
  • 35 Answers
A can of compressed air will work fine. Make sure you hold it up right. Holding it upside down will cause moisture to spray out.
Posted on Aug 19, 2008
Toshiba Satellite L500D is shutting down by itself OVERHEATING Clean the fan with compress Air ....> NO GO Need help Please or Any other Suggestion
Disassemble the laptop and remove the heatsink.
Remove all the dried up heatsink goo that's on the heatsink and processor.
Squeeze a small amount of QuickSilver heatsink compound onto the middle of the processor top.
Place the heatsink on the processor and move it in a couple small circles before locking the processor heatsink back in place.
Clean the air vents and cooling fins well while the unit is open.
This should fix any overheating issues you are having (assuming the fan is OK)
If the fan isn't running, replace it.
Jun 24, 2011 | Computers & Internet
My acer aspire 8930 9600m gt gpu keeps overheating what is the problem
Gaming (and graphics application) consumes more CPU/ Processor resources and due to the heavy processing the PC (CPU & GPU) heatup. Excessive heatup beyond usual is alarming and PC shuts down by itself when the processor/ GPU temperature exceeds the safe temperature limit. There are mainly two reasons for heatup.
Laptop heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another most likely cause of overheating is the dust present inside the laptop, which clogs the fan and heatsink.
1. Make sure the fan is running. (if not it needs replacement)
2. Clean the fan and heat sink (thermal module). Click here for laptop disassembly instructions and refer to
Removing the System Fan/Thermal Module after removing the outer cover. Take out the fan and heat sink. clean them with the help of tooth brush and put it back. Also, repair manual can be searched online or downloaded for referrence.
The procedure is very simple, but if you are not comfortable with working inside electronics, I suggest that you should get you laptop checked by a professional for servicing (if required). I believe immediate action is required to prevent any damage to your machine and data.
Hope it Helps! Let me know if i could be of any further assistance.
CreativeTECH
Apr 16, 2011 | Acer Aspire AS5252V333 Notebook
I purchased my laptop in 2009 from currys and only recently its beginning to make noises from the base of my laptop it sounds like iv a problem with the fan of the laptop would this be causing my internet...
Sounds like the fan could be pulling the cpu down or it's overheating. The cpu fins may need cleaning and will stop overworking the fan and start cooling as it's suppose to.The fan itself could be dying.
Jan 11, 2011 | Computers & Internet
I have a dell inspirion 1525 and it over heats and shuts down all the time
Check the fan in the vents if they are still working, if yes, clean them, you can do it with a can of compressed air.
If the fans are not spinning anymore, you'll have to replace them.
Jan 03, 2011 | Dell Inspiron 1525 Notebook
My acer aspire 5315 shuts off suddenly and won't restart till it wants to. I replaced the battery, no difference....what's wrong?
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced
Oct 22, 2010 | Acer Computers & Internet
I have a Dell M90. It has shut down due to overheating. Now it will no turn on. Do you think this could be a fan issue? I purchased this 7-5-2006
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Sep 20, 2010 | Dell Precision M90 Notebook
My Eee netbook just shuts off, the fan keeps running untill i get the black screen which can mean its overheating because the fan is constantly running. Please help me fix this problem ive spent way too...
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 20, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My IBM lap top seems to be overheating, it has started to shut down, I just guessed it was from over heating, it has done it quite a few times. It is on a docking station, so I wonder if it isn't getting...
The problem with the laptop is that the Main board fan needs to be clean. It could have accumulated a lot of dust. Try cleaning the fan and the laptop would be faster than before and seize shutting down.
Before that I would advise you to update the BIOS which will be available in the manufacturer's website. This could also resolve the issue.
Fan cleaning must be done in such a way that the laptop must be disassembled and clean the dust in the fan.
Assemble the parts once again and the laptop would be as good as new.
If you fear disassembling the laptop you can contact the manufacturer tech support to have the fan cleaned.
Jul 08, 2009 | IBM ThinkPad X61 Tablet PC
Dell latitude laptop-freezes after running for a few minutes/sometime on start-up/screen on but no response /fan stops running and nothing responds
Im assuming its a C64, these notebooks have overheating issues.
1. make sure the fan has room to breathe, and is clean of dust.
2 Dell Inspiron/Latitude/Precisiion fan control utility will help cool your processor ... http://www.diefer.de/i8kfan/index.html
Jun 04, 2009 | Dell Latitude C640 Notebook
Toshiba Satellite A105 Notebook Logo
47 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
