Ricoh Aficio 3235 Copier/Scanner It appears that the pages are scanned. Then, error reads: Authentication with the destination has failed Check settings. Yesterday, everything was scanning to folders correctly. This scanner is on a network, pages are scanned to network folders. Any suggestions/thoughts/ideas? I greatly appreciate your help. Thanks, Teri
  • unit_0_0_1 Oct 13, 2008
    I started getting this error after switching my broadband connection from a T1 to a DSL. The connection is through the same provider and even uses the same DNS servers.
  • Anonymous Feb 22, 2009
    Same issue
3 Suggested Answers
  • 5 Answers
SOURCE: problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Posted on Jul 22, 2008
  • 86 Answers
SOURCE: Printer shows offline/Scanner has no destination list
You must program the email addresses in the machine address book, so that you will have a destination list to scan to email.
You can also try to scan by pressing the Scanner button to access the scanner function and input the email address manually by selecting manual, and then press the Start button to scan the document.
Joe
Posted on Jan 10, 2009
I used to be able to scan a lot of documents and then just last week I couldn't scan any document using the Ricoh Aficio Type 2018. The message "Sending has failed. Press Job Information key to check the...
It is a problem with the network connection, if you are using scan router recheck the configuration settings in case of scan to email check connection with smtp server, port no. ssl on or off and do the connection test, check mail server authentication, rest assured it is not a problem with the machine or GW controller.
Feb 18, 2015 | Ricoh Aficio 2018D All-In-One Laser...
When I try to scan from my new Ricoh SP 250 to either email or desktop folder I get the following error message: "Server Response Error"
Have you setup mail server on copier as for desktop did you setup a share folder on computer. Have you gone in create a user with email info and scan folder path and Both might need to be authentication . Go to ricoh-usa.com/download and in search area enter model and click on manuals will explain setup for this.
Oct 13, 2014 | Ricoh Aficio SP C210SF Multifunction...
SMTP Scan to email problem on a Ricoh MPC2500
Ricoh scanner uses a email account to send the scan to email. That email account has the wrong password on Ricoh settings, probably someone changed the password and now needs to be updated. I hope it helps.
Apr 29, 2014 | Ricoh Office Equipment & Supplies
Ricoh scan email
get operation manual for email and scan will explain how to set it up. or have copier technician come out.
May 14, 2013 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Ricoh Aficio Sc 122
The scanner home position sensor
does not detect the home position
during initialization.
Causes:
Scanner I/O board or SBU defective
• Scanner motor defective
• Harness between scanner I/O board
and scanner motor disconnected
• Scanner HP sensor defective
• Harness between SBU and HP sensor
disconnected
• Scanner wire, timing belt, pulley, or
carriage defective
Aug 14, 2012 | Ricoh Aficio 2232C Color Copier
The ir 3235 is displaying E000280 - 003 i want to know the cause of this fault
ricoh aficio 2105 error code 32836 the scanner is not working please help soon
Sep 06, 2011 | Ricoh Aficio 2015 Copier
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Joe
Dec 18, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Scan
Yes you should be able to set up a destination in your address book. The folder must be shared. Click here for the scanner reference for this machine for more information.
Here is a link to all of the other manuals. Hope this helps. Let me know if you need more help.
If this helps you out, please rate this as fix ya.
Nov 25, 2008 | Ricoh Aficio 1035 Copier
2,631 people viewed this question
jasbo
jasbo
