Question about Singer CE-100 Futura Computerized Sewing Machine
I have a Futura CE 150 and it has been working great. I just started using it again, and now when I stitch it out on the edges it has the bobbin thread on it.. I threaded the bobbin right, and also the top thread. It still has the white on the edges of the thread. what can I do????
  • spazii Aug 12, 2008
    I am having the same problem with my CE150. I have adjusted the thread tension--trying to see if this solves the problem, but my designs still have the bobbin thread showing around the edges. I have tried many different types of fabrics and always stabalize correctly. But still, the problem persists. HELP! I want to embroider!
This has worked for me.
1. Make sure the tension dial is set at E.
2. Remove the bobbin case with thread in it.
3. Tape three quarters to the end of the thread.
4. Hold the bobbin case up. Given your problem, the quarters should be dropping to the ground.
5. Tighten the tension screw until the quarters are just a tiny bit away from dropping. You don't want it tighter than that because it will be too tight.
6. Put the bobbin in and test embroider.
This fix came from Jim at the Futura Yahoo group. It is a group well worth joining.
Posted on Jan 29, 2009
  • familyof9 Oct 13, 2011
    what??????? Quarters??? Of course they'll fall. They are heavier than the thread.
Why cant i install futura ce 150 softwRE with windows 10?
Singer Futura CE-150, I NEED HELP!!! - FreeEmbroideryStuff ...
freeembroiderystuff.embroiderydesigns.com/forums/threadView.aspx?id...
Jul 11, 2014 - 15 posts - ‎10 authors
I just got the Singer Futura CE-150 and every time I start a design it ... Posts: 2/10/2014 11:18:44 PM, RE: Singer Futura CE-150, I NEED ... Futura CE-100but didn't realize it didn't have its original install cd with ... I can't afford Singers price. ... -Software-Download-and-Installation_A287.aspx?id=287&siteid= ...
Singer futura ce-350 software download - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesJavaScript isn't enabled in your browser, so this file can't be opened. Enable and reload. ... Singer futura ce 150 embroidery machine 3900 designs dvd. Top 3 singer ... Singerfutura software for windows 10 memphis soft portal. Using my singer ... Singer futura software installation for windows 2000 xp youtube. Service ...
Singer Futura CE-250 Sewing and Embroidery Machine w
SINGER® FUTURA™ Software Installation for Windows ...? 7:20https://www.youtube.com/watch?v=RDkHyrh0ejkNov 30, 2009 - Uploaded by SingerSewingCompanySINGER® FUTURA™ Software Installation for Windows 2000 & XP ... yes i already have a singer ...Singer Futura will not work with Windows 7 - Microsoft Communityanswers.microsoft.com/.../singer-futura.../da1ea4db-8594-4a12-91d1-d8...I bought a Singer Futura sewing machine and a Win 7 laptop for Christmas. ... can find the right person at Singer to talk to they might let you have a pre-release version of thesoftware. ... What if you download the patch and it still doesn't work? ... if you are using ce-150 go to http://futura-support.com/downloads/ce150.html.
Dec 30, 2015 | Sewing Machines
I have a futura ce 150 and my bobbin thread won't catch
Are you able to bring the bobbin thread to the top of the needle plate, but it's skipping stitches, or you can't "catch" the bobbin thread to start sewing at all.
If you can't "catch" it at all, your machine's hook is no longer synchronizing, and you will need to have it retimed by a technician. The good news is, timing is not something that is unique per manufacturer, which means ANY sewing machine technician should be able to do it.
Sep 25, 2014 | Singer CE-100 Futura Computerized Sewing...
Have a c-150 furtura ...i'm getting a bad stitch on the bobbin thread with both reg and embroidery stitching how do i fix this been in repair shop 3 times comes back with still bad stitch they use...
ANOTHER THING IS TO CHECK THE TENSION OF THE BOBBIN THREAD. MAKE SURE THE THREAD YOU ARE USING IS GOOD THREAD THAT DOESN'T PULL THE COTTON UP AND CAUSE A PUFF BALL ON THE NEEDLE. CHECK THE WAY YOU ARE LOADING THE TOP THREAD. ALWAYS DO THIS WHILE THE FOOT IS UP SO THAT YOU CAN CONTINUOUSLY GIVE TUGS THROUGH EACH OF THE GUIDES. THIS HAS TO BE LITTLE TENSION WITH NO SNAGS.
Apr 23, 2014 | Singer CE-100 Futura Computerized Sewing...
Does not stitch, just beeps
try changing the needle
try rethreading the machine top -make sure to use every thread
guide & bobbin--make sure the bobbin is turned the right way in the
bobbin case
clean under the needle plate & in the bobbin area for lint
also try turning the machine off & then back on & see if that will
help
Oct 07, 2012 | Singer CE-200 Quantum Futura Computerized...
Futura 150. Using autopunch. The machine does some of the
have you tried changing the needle?
it could be a part of the computer is mal-fuctioning
it could be out of time
it needs to be serviced to find out what's wrong with it.
Mar 22, 2012 | Singer CE-200 Quantum Futura Computerized...
Singer ce-200 jerks between stitches only when it goes slow.
Are you using a good quality bobbin thread? Is the machine cleaned and oiled? Is the bobbin in place like it supposed to be?
Oct 31, 2011 | Singer CE-200 Quantum Futura Computerized...
The bobbin case keeps coming out of place.
Make sure you are using the right bobbins. They recommended the ones that are plastic with SMOOTH faces versus the metal ones that have holes and a center core that can snag the thread as it passes over the bobbin. If it snags it will disturb the bobbin case.
Dec 07, 2009 | Singer CE-200 Quantum Futura Computerized...
Need Help putting the bobbin case back in the futura ce 100?????
With the needleplate removed, locate the black plastic bobbin case in horizontal and level position with the "bull horn" facing the rear, so the needle has space to move....
Gently place finger on top edge and move bobbin case, there ought to be a small amount of movement (1 or 2 mm slack) to allow passage of thread past the stopper spring (at front right)
If there is no slack at this position, have you adjusted anything to "tighten it up a bit", if so, relax the stopper spring by an "almost nothing" amount (again, 1 - 2 mm) to allow the thread to form the stitch.
....if you have had some needle strikes and damaged the surface, fine emery paper may be used to smooth the damage, if significantly scored, replace the bobbin case.
Feb 18, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer ce-100 futura
Hi justmewynn, The url I am adding to this post may be of help. It is a pdf file from Singer contain many diagrams of the CE-100. Maybe you cqan page through it and find what your looking for. Hope this helps you. http://www.futura-support.com/files/CE100-Eng_Fre_Spa-77153.pdf
Sep 27, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
190 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
