Hi, Got a triton t30i handwash. The mcb is OK, buut when I put on the isolator switch, without turning on the handwash the water starts boiling inside the handwash itself. Once on the water is steaming out. Can someone help? Molbee.
  • 44 Answers
SOURCE: Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Posted on Dec 15, 2008
  • 3 Answers
SOURCE: kettle shuts off before boiling?
I had a similar failure. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
In my kettle the contacts did not line up correctly. Instead of making good contact they were only partially overlapping like a couple of the olympic rings or a couple of rings from the Audi logo. This resulted in a localized increased resistance and high heat in one of the contact holders which eventually melted the surrounding plastic. At that point the wires going to the element behaved a bit like springs which forced the contact holder further out of alignment until it all became hot enough to trigger the thermal switch.
I fixed it by bending the contact holder, which is fused into the now hardened plastic, to the optimal position and hopefully it will not generate enough heat to remelt the plastic or trip the thermal switch.
I have boiled a couple of kettlefuls; so far so good!
What ticks me off about this is that I don't mind getting 'Made In China' ****; everything comes from China anyway. But don't charge me a ridiculous amount of money and try to pretend that I am getting a superiour product. If I had paid twenty dollars or less for it I would just chuck it and get the same one again because it looks nice, pours well, doesn't burn the hands, worked OK for couple of years, etc. Instead I walk away from this feeling really ripped off. I have a house full of Braun products(shaver, kettle multiple tooth brushes) but now I won't buy any more.
Oh and if you take your kettle apart and your house burns down it is not my fault. There, now I feel better.
Posted on Apr 12, 2009
  • 43 Answers
SOURCE: swan steam iron steam coming out of front and leaking water
the temperature is not set correctly for the fabric.
Posted on Sep 18, 2009
  • 109 Answers
SOURCE: i cleaned the whole gaggia classic (boiler
It could be the steam solenoid or the small hole in the group head next to the screw holes gets blocked up as well.
Posted on Feb 05, 2010
  • 5 Answers
SOURCE: hi i just installed a triton cara shower and the w...
It is probably the water solenoid valve wich is stuck or bunt out.
If it is brand new, maybe you have warranty.
Posted on May 25, 2010
MCB keeps tripping
Could be a blocked outlet pipe were you carefull with the sealing washers.? if the pump is getting back pressure and struggleing it may overheat and blow or maybe remove the mesh filter if one is fitted
if a simple reason is a not apparent do not fiddle around any more isolate the supply and find an electriction there is serious voltage in the there enough to start a fire or kill you ! please be carefull best of luck !
Dec 09, 2013 | Heating & Cooling
On my bmw318i is to much stim and the water blows up but without thermostat its ok just dont reach the tempeature. many thanks glen
HI HAVE YOU PUT THE THMOSTAT IN A BOWL OF HOT WATER TO SEE IFF IT IS OPENING PUT SOME STRING ON IT AND LET IT SOAK IN BOILING HOT WATER.YOU WILL SEE IF IT OPENS .IF IT WONT IT WANTS REPLACING..THEY HAVE WAX INSIDE AS IT MELTS WITH THE HEAT IT OPENS UP.
Jan 31, 2013 | 1999 BMW 318 ti
My triton shower won't turn off and has no hot water
Your supply pressure is too high for the unit, it is too much for the solenoid to shut off, you need to put a pressure limiting valve inline.
Mar 10, 2012 | Home
We have triton cascade power shower and the water keeps coming out even when the power is isolated.
I too am having exactly the same problem with my triton 300 si. I have noticed that since this behaviour started the red light around the on/off switch is no longer illuminated (whether it's on or off).
I have tried calling the technical support but they wont help since it's out of Guarantee. Have you noticed any other features missing or not working?
Aug 01, 2010 | Hansgrohe Showerhead Shower Power ...
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Apr 05, 2010 | Home
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
