Fig. 1: Exploded view of the belt drive fan assembly-1992 vehicle shownTo install:
1. Position the fan on the drive clutch. Install the bolt and washer assemblies, then tighten to 12-17 ft. lbs. (16-24 Nm).
2. Position the fan drive clutch, fan assembly and fan shroud, then bolt the fan and clutch assembly to the water pump hub. Install and tighten the clutch retaining bolt and water pump assemblies evenly and alternately to 15-22 ft. lbs. (20-30 Nm) for the 3.8L engine or to 36-47 ft. lbs. (48-65 Nm) for the 5.0L engine.
3. Install the fan belt. Align the fan shroud and adjust for equal fan-to-shroud radiator clearance but maintaining a minimum of 0.38 inch clearance to the fan tip on 5.0L engines.
4. Install and tighten the shroud retaining screws. On 5.0L engines, snap the air deflector assembly to the sub-frame cross brace.
Hope helps (remember to rate and comment this
