Question about Sony KP-61HS10 61" Rear Projection Television
Noise in sony tv
I have a sony tv 61" plasma. It makes a funny click-click sound after running for a while. no effect on picture quality though. Any suggestion-can it be colling fan..
  • 10,594 Answers
It needs service to clean inside. this click sound is spark of high volts, generated by H-V block, got carbonise dust ( black ) arround it.
Posted on Aug 12, 2008
How to fix a 58 in plasma tv that makes a clicking noise ; no picture
SOUNDS LIKE A FAULTY RELAY HAD THIS FAULT PREVIOUSLY ON SAMSUNG -SONY-TOSHIBA
Jul 25, 2015 | Samsung PN58B560 58 in. HDTV Plasma TV
No sound or picture but lights come on sony wega plasma
Typical failure for all plasma tv's is a blown Y-sustain board. Another high failure for all tv's is dried out bulging capacitors in any of the power boards. You likely have one of these problems.
Mar 18, 2015 | Sony KDE-42XS955 42 in. Plasma HDTV
50PFP5332D Plasma tv. My tv sounds like its trying to turn on but the blue light flashes and a clicking noise keeps repeating and no picture.
I have the same problem with my TV. I haven't verified this yet, but someone I know who's a electronics genius told me that its the buttons on the TV (power, channel, volume, etc.) He said at the factory many of the "button boards" were tightened too much and cracked. When you turn the TV on, the clicking noise is a loose connection. He said it's easy to replace yourself, and about 30 bucks on ebay. No promises though.
May 20, 2010 | Philips 50PFP5332D 50 in. Plasma...
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
52" plasma tv - turns on - and I hear something reset inside
i hear a clicking noise- the clicking noise is most likely you ballast trying to power the lamp, but failing. this may indicate a defective ballast if you have recenty purchased a new lamp.I recomend you have your lamp tested to help narrow down the cause of the defect. It's highly unlikely for a new lamp to be dead on arrival
Dec 04, 2008 | Dell Televison & Video
I have a Panasonic Viera 37" plasma TV which is nearly 3yrs old. Picture input is from Sky HD via hdt lead. Most times pic quality is brilliant on both HD and none HD. However I occasionally experience...
This is a fault definately. I have run into this with Samsung plasma tv's and find if you do some electrical adjustments you can usually remedy the situation. Sometimes though, it is the panel going bad or a board. Do u have any pictures i can see? Also keep in mind that if you have a DVM you can make the adjustments yourself. Good luck...GURU JAY
Feb 26, 2008 | Televison & Video
42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
sounds like it may be a software upgrade
Oct 16, 2007 | LG 50PX4DR 50 in. Plasma TV
61 Inch Sony Plasma KE-MR61 needs to be repaired
Ke series makes that an early plasma TV
that old will probably be throw away or requires the replacement of the whole printed circuit of the TV
or power source
if chinese built that circuity may no longer be available
any local mobile TV repairer can check that TV out for you
check out the internet for sony corporation south africa
for parts availability
Mar 30, 2017 | Sony WEGA KDE-61XBR950 61 in. Plasma HDTV
Sony KP-61HS10 61" Rear Projection Television Logo
51 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
