Question about Brother ML-100 Typewriter
Correction Tape I replaced the multistrike ribbon 1031 and now the correction tape does not correct. The instruction manual pictures are not good and I can't see what they are considering the ribbon guide..????
  • mmarin Sep 18, 2008
    I'm not sure how to put the correct tape on?
    Sergeant:
  • 329 Answers
The correction tape which should be a yellow spool and the correction ribbon cartridge should be a yellow also, sometimes orange, first. The correction tape has to in front of the black correction ribbon. in othe words this is the order. Platen, paper, correction tape, correctable film ribbon, printwheel. Also make sure correction tape is dull side toward paper. Shinny side should face operator...
Posted on Aug 13, 2008
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
Dec 27, 2010 | Brother ML-100 Typewriter
I have an AX-22 and when I replaced the correction
You probably don't have the dull toward the paper.
DickyO
Mar 15, 2010 | Brother Office Equipment & Supplies
Replacement of correction tape
The correction tape cartridge "piggybacks" under the ribbon cartridge. Flip your black ribbon over, line up the front dges of the two ribbons and gently press down on the correction ribbon 'till the two wing tabs at the top are attached to the slots at the top of the black ribbon. Be sure to take up any slack in the ribbons BEFORE re- installing.
GL
Jul 06, 2009 | Lexmark Wheelwriter 15 Series II...
Replaced Typewriter Ribbon & Now Correction Tape doesn't work
Is the ribbon that you installed a correctable one? It should have a yellow or orange knob to turn it. If that knob is blue, you installed a multistrike or non-correctable ribbon.
The only other thing is you have the correction tape in backwards
Jan 12, 2009 | Brother SX-4000 Typewriter
Ribbon/correction tape
Ribbons:
Correctable film - MODEL 1230 or 1030
Nylon - MODEL 1032
Multi Strike - MODEL 1031
Correction tape:
Lift-off - MODEL 3010 for use with correctable film ribbon & cover-up - MODEL 4010 for use with nylon ribbon and multi strike ribbon.
Aug 22, 2008 | Brother SX-4000 Typewriter
CORRECTION TAPE
correction tapes will not work with multistrike ribbons. You have to use a correctable ribbon. If you can find a white out tape, it will work with multistrike. What model typewroter do you have?
Aug 12, 2008 | Brother ML-100 Typewriter
Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 17, 2008 | Brother ML-100 Typewriter
Correction tape
To replace the correction tape:
1) use [SPACE BAR] or <<-¦ to move the carrier to the centre of the platen
2) open the top cover
3) remove the cassette ribbon (if installed)
4) pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen and lift it up and out.
5) Pass the new tape through the left guide, behind the ribbon guide, and out thropugh the right guide. The rough (stick) side of the tape should face the platen.
6) Attach the feeder spool to the pin on the left
7) Attach the take-up spool to the pin on the right
8) Turn the take-up spool counter-clockwise until a small amount of white tape has wound around it
9) Replace the cassette ribbon and close the top cover
10) Press 'spider web' key +// to move the carrier to the previous position.
Hope this helps.
Regards TC
Jul 16, 2008 | Brother GX-6750 Typewriter
Correct key
Jul 07, 2008 | Brother ML-100 Typewriter
Brother ML100 Lift-Off Correction Tape won't lift off
Correction tapes DO have a shelf life, Also make sure the ribbon is moving and very important and this may sound dumb, but I have seen it that the ribbon is not a correction ribon. Are the spool turns orange or yellow? should be. Blue is multistrike and will not correct. Don't know the shelf life of ribbons but they do loose the ability to correct.....Good luck try new supplies..
Jun 30, 2008 | Brother ML-100 Typewriter
Brother ML-100 Typewriter Logo
464 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
